I think perhaps there needs to be some clarification on what you mean by ‘lock-stick’. I have two Fällkniven liner lock knives that are solid as the proverbial rock. Absolutely solid and reliable. The lock release is easily actuated and there is no ‘stick’. I fail to understand how this lock could in any way be inferior to a lock that ‘sticks’. The only sticky lock I have is on an ESEE framelock Avispa - I regard it as yet one more failure on an already flawed design.Lock stick is literally caused by the metals galling together. Unsticking is the titanium face losing a layer of metal. Lockstick tends to increase the wear ln a lockface because of this. So it can wear the lock into not working.
Lockstick isn’t a bad thing in my eyes. But I prefer for a sticking lock to wear into a sweet spot where lockwear slows down exponentially. To me this is better than a lock sticking and wearing all the way to the other side.
Also if the lockstick is weak enough that it is easily overcome by one hand then it’s not providing anything but superficial security anyway. If it is a lock that would fail otherwise but only stick is preventing it; then it will only take a little bit of force to the spine to cause it to unstick just like it takes only a little force to unlock by hand.
I’m saying that the extra margin of security lockstick will give you to a lock that would fail without that lockstick is not what a well built lock is all about. Light lockstick is totally secondary to good geometry.
The Avispa most specifically. Some appalling ‘design decisions’. The sort of thing that causes red faces in board rooms, and in many organisations would result in immediate redundancies. It is pretty, that’s about it.The Avispa specifically or frame locks in general?
Ah! Yes, I do regard you as somebody who speaks good sense. My misunderstanding.There must be some misunderstanding. I’m saying lockstick tends to be a bad to neutral thing, not a neutral to good thing. I would rather a lock with no lockstick that is solid due to good geometry rather than a lock where I am counting on stick as a safety feature.
I typically find lockstick to be a bad thing for a number of reasons including tending to wear faster.
I don’t buy into frame locks full stop, so I would not feel confident to pronounce either way on them.
Don’t like the feel of ‘em! Simple as that. I have all sorts of foibles, and my wallet is healthier in girth due to some of them.You don’t like framelocks at all? I obviously respect your opinion but can I ask why?
Especially why you exclude framelocks but apparently not linerlocks?
I snigger at all these arguments over framelocks and their viability. I will at some point inevitably buy a CRK, just because, and that would be an exception for me. But I don’t doubt that a well executed framelock is every bit as decent as any other well executed lock, within what I would call reasonable use.
I am often bemused by certain attitudes among knife enthusiasts, and it is fairly easy to spot those who use knives outdoors in a sensible way. Sensible being with a view to preserving the usefulness of that tool by thinking, rather than merrily hacking away with what was once called, ‘gay abandon’.
I’m sorry, but your comments don’t make any sense.Locks, be it frame, liner, or sub-frame, are supposed to mildy gall. That's if someone wants a tool. If someone wants a stick free lock then they are concerned with the knife's fidgetability. That's fine, but just know whether you want a fidget toy or a tool. If a company is more worried about ease of disengagement of the lock than of the lock operating as it should, then simply realize you're buying a toy, not a tool.
And I seriously doubt anyone has, through real world use, ever encountered a lock face from a good company that genuinely wears out from anything but purposeful and unnecessary abuse or a manufacturing defect.
In reality, most people here want high end toys rather than tools and companies know that so they produce toys.
Locks that operate on different principles than frame, sub-frame, or liners are exactly that, different. You won't see these arguments about the triad or compression or axis type locks because they can be smooth and perform as tools. Different strokes for different folks. But ask yourself if you want a tool or a toy and if you want a tool with a lock that performs smoothly and yet still functions as a tool, don't buy a knife with frame, sub-frame, or liner lock.
It'd be like asking for a backlock knife that has no tension to keep the blade in the handle just because you want to fidget with it. It defeats a major intended purpose of the feature.
I've had a few US-made Kershaw Speedsafe frame locks that were the opposite of sticky; they were 'mushy'. They would barely engage and felt weak/loose. I guess that could be considered a 'lazy' lockup.
I had/have some Emersons whose liner locks would 'pop' out of the locked position slightly when pressing the blade spine in the open position. They never fully unlocked and closed, but those liner locks also felt 'mushy'. I haven't bought an Emerson in maybe 15 or 16 years, so things might have changed with Emersons. A big issue with the ones I had that 'popped' out of position was the blade tang locking surfaces were ground way too steeply, which would create premature wear and make it easier to develop sloppy locks in a relatively short time.
My all-time favorite liner lock design is the Spyderco Military. I have 3 of them, and have never had any lock stick, lock rock, nor any over-travel to the opposite side. Great materials, and excellent gradual concave angling (not too steep, not too flat) on the blade tang mating surfaces.
In frame locks, I've never had a problem with any of my 5 CRKs. I know people are probably tired of hearing about CRKs, but since 2002, I've never experienced lock stick nor any weakening of a CRK frame lock. They seem to wear very minimally over time, then just stop dead in one spot. Or so it seems to me.
Jim
what's the problem with having a mildly sticky lock?
Chris Reeve Knives;7284330 said:This thread was brought to my notice so I thought I would make a couple of comments. We do not recommend that anyone adjusts the tension on the lock bar - i.e. pushes it one way or the other. The result of doing this will probably be blade play. When Clay told Rickster "...To repair the condition all they due is disassemble the knife & bend (Tweek) the lock-bar a little at a time..." you have to bear in mind that Clay and Thomas, who are our two assembly guys, do this all the time and they are trained to recognize a variety of other factors that go in to perfecting the lockup. The tolerances around the lock/pivot area are sufficiently close that if you move one thing, another is going go out of whack!
No doubt some of you have "tweeked" your Sebenza locks with no resulting blade play - that's been fortunate! We still would prefer you send the knife back to us if you are not happy with the lock. Our recommended tolerance is 50-75% - if it goes over further, and there is no galling or blade play, that is even better!
BTW - a technicality: as much as we enjoy having Clay on our staff and how great a worker he is, he is not the Shop Foreman!
Anne
Zenith;749285 said:Not really. The routing that is done is to make the disengagement for the user more comfortable. STR has made Ti framelocks without any cut-outs (routing) because the user wanted it only to have it returned later on because the user complained it was too difficult to disengage.
The cut-outs (routing) also provide a "safe burn" for those "accidental moments" when the lock does fail due to excessive force on the blade.
An Emerson HD-7 showed this perfectly.
http://strsbackyardknifeworks.blogspot.com/2009/07/bins-horseman-hd-and-jryan-edc-folder.html
In short
"Contrary to how many readers may feel about that picture above. That my friend is a design that deserves praise for defeating the way it was engineered to go. That HD7 above did its job and so did the designer/maker of the knife. I doubt any sutures or ER trips costing great amounts of money were needed with that defeat. We should all pray to be so lucky should we be the on the unfortunate end of a defeat ourselves one day."
The cut-outs are the weakest link in a Framelock IMO.
I have been surprised by some framelocks. A Kershaw vapour that I had would disengage with some force on the spine when not held in hand. When I gripped it the lock did not move as ones fingers actually force the lock in.
Zenith;749294 said:Titanium that is used in framelocks has to be at least grade 5 quality. It has natural spring tension if I can remember correctly.
Zenith;749554 said:Dwayne
Emerson knives start live out so early because it is the Mr. Emersons personal choice for his locks. I know of custom makers that also do this.
However, in my experience it is Ti liner locks such as Emerson knives (and there are many others that also do this) that are not heat treated or carbodized lock faces of the springs that tend to wear much faster. In these locks the geometry of the lock has to be as close to perfect as one can get.
Chris Reeve.....well this is interesting because he is credited as the father of the "framelock" or R.I.L.
The reason why his knives do not really have a break in period, or if it has it is very little is one thing: Tolerance.
CRK also does what I feel is good practice in that they adopt the blade to the spring, not the spring to the blade. In other words, when they fit a blade to a lock, they have multiple handles that are pre-assembled, checking in which handle the blade fits best and then if required they grind the blade LF area to mach the spring. They never fiddle with the spring or springs LF area after it has been heat treated and bead blasted to match the blade. This is good practice IMO and great makers do this.
The only real advantage steel has over Ti is not in its wear resistance, but IMO in its impact resistance if one wants to beat the :spyder: out of the spyderco or other knife.
(I wanted to ad that my knowledge is not perfect and if any maker wants to correct me I am willing to learn, I am just sharing what I have learned from makers and books)
Zenith;749571 said:It does not really matter if the company is Emerson or not, the quality control needs to be good and with whatever company there have been a few melons going through. This is wear warranty comes into play.
The thing why Emerson knives wear so fast is due to the wave feature. If you wave that knife 20 times a day at full speed then the lock will wear faster.
The second question I don’t fully understand, could you elaborate on it a bit before I attempt to answer it in full?
If you are referring to why CRK knives start locking up at 50%, that is his preference (mine to) and the LF is designed and executed that way.
The initial wear on a CRK is minimal due to the close tolerances on the LF and the entire knife. However, sometimes there is a rough spot on the LF that just wears smooth and the lockup will increase from 50%-60% within a few days, or weeks, but after that it would wear very slowly. CRK wants the lockup to be between 50%-75%, but this is different on the Umnumzaan. On the Um it looks closer to 90% but it is actually 75% and I have yet to hear a complaint about the Umnumzaans LF or geometry.
GarethBull;11923 said:^ Nice post budThat zone of 7.5-8.5 degrees really is vital. For those of us visually inclined:
Des Horn;11955 said:I do not believe this is wear.
In my view this is "setting" of the face to a perfect fit against the blade, and once there it does not move.
This is a really great thread giving lots of advice to the novice makers.
