- Aug 1, 2000
Holy Smokes!.....I didn't expect to much action here....whew, slow down guys!
Very good info getting posted.
Mark, it looks like your the guilty bastid for hijacking the thread from hollow grinders to surface grinders
(Thank you for the order BTW).
I looked into surface grinders in the past. And actually looked a few designs that guys sent me. After looking....I concluded that it is hard to beat the little grizzly surface grinder model. I think it runs $1200-$1500. Has micrometer Z, and both X-Y slides, precision ways...single phase input....etc. I don't know how you could get this much value or precision starting from scratch with a new machine design.
Back to hollow grinders:
A 36" wheel will turn slow.....I'm thinking about 400-500rpm for hogging. There is no issue on torque, hp and speed. They are all related and one trades-off with the other. HP is the product of speed and torque. For a given hp, if you reduce the speed, you increase the torque..and so on. A drive train that reduces the speed will proportionally increase the torque. It is the basic input=output thing. If we put 2 hp worth of electrical power into the machine, we will get 2 hp out...in one form or another.
I'm really leaning toward a 36" wheel myself......why stop at 20..? heck if you want a flat grind then bigger is better...but 36" is the limit based on machine tools needed to make it....otherwise we could keep going.
A few issues regarding driven or coasting contact wheel....
If the contact wheel is a coaster ...then there is trouble starting the grinder. The probelm is that the drive wheel spins and throws the belt off because the big wheel has too much inertia and takes a while to spool up. I see this on KMG with 14" wheels and high powered motors (5hp). A solution would be a motor controller (VFD) with a ramped accel for starting...or soft start. Then, what about tracking?... it is much easier to use an idler wheel for tracking adjustment... I think it would be impractical to steer the big contact wheel. Small adjustments would make BIG changes in the belt position. If you use specialty fixtures, you might not want to move the wheel after the fixture is set. ....hmmm...more thinkin' to do...... Maybe move the motor with the drive wheel for tracking....and for tension
.... gotta think about it more.....
Keep the ideas rolling...
Sincerely,
Rob
Sincerely,
Rob
