Originally posted by R.W.Clark
Thanks for the mention, but I would have to pass on this one. My dance card is just a little full and that small of a knife with that thick of stock just makes no sense to me at all. The edge geometry would be all out of wack. It would not cut worth a darn.
jggonzalez, you misunderstood my statement. There is more to cutting than just a sharp edge. I could take a square bar and put a slicing sharp edge on it, but that does not mean that it is a good cutter.
When considering the cutting performance of a knife you must consider how wide the blade is (edge to spine) vs how thick it is. This gives you your edge geometry. Too steep an angle and the edge will be brittle because there is not enough material to support the carbides. Too obtuse an angle and you will be encountering more resistance than is needed due to the blade having to push the material a greater distance outward to allow the blade to enter.
This is the fine line that most makers walk. Getting geometry that will make a strong knife vs getting the best cutting performance. With the high performance steels today, we can make the blades thinner (better geometry) without comprimising strength.
In my mind at least a blade is a tool for cutting a given material. I would no more ask my knife to pry than I would ask my grinder to drill holes. When I need to cut I have the optimum tool for the job and when I need to pry I have the small titanium pry bar that is always a part of my EDC gear.
If you like a heavier knife, you can get the same effect and still have a prime cutting tool. It is easy to add extra weight under the handle slabs, although I have never had a customer request such a custom mod.
... I have the small titanium pry bar that is always a part of my EDC gear.
