- Aug 5, 2014
I just made a kitchen knife (Gyuto) from a steel in the W1 family (spec SK4) and decided to go quite thin on this one. After hardening (1500F into Houghton's K and temper at 400F) I took it down to about 1.8mm (.070) at the spine above the heel.
As I was doing the post-HT grinding the blade began to warp repeatedly on each side...in fact I continuously "countered" the previous warping by flipping to the other side and grinding until it warped a bit in the other direction.
In the end, using this technique I was able to get it almost straight but it now has just the slightest bit of warp to it that I couldn't get fully out. My question is, what's the best way to fix this?
I've previously seen folks recommend bead blasting one side of the blade, or shimming/clamping and tempering again. I don't have a bead blaster and I'm a bit worried that the fine edge will overheat quickly if I try to temper again...thanks for any advice
