Cobalt
Platinum Member
- Dec 23, 1998
Buzzbait said:I have owned knives from both Busse and Strider. While I found both companies to be lacking in the fit and finish category, both brands had their ups and downs..
While I can't speak for Strider, I can say that I have never been dissapointed by Busses fit and Finish, although I am sure that a few get out. Specifically what knives did you get from Busse that were lacking in fit and finish and when did you get them?
Buzzbait said:I had definite rust issues with the INFI though, which should be expected. This is not a stainless steel. The rusting issue, in my case, was made even worse by the pitted finish left on the blade tang. Striders combination of S30v and blade coating was far more rust resistant than my unpainted INFI blade. Painted INFI is something I have not used extensively, but it should be stainless enough for all but the worst of environments. .
Funny I have not had any rust issues with my infi and I have left multiple SHBM's laying out n the backyard several times during bad weather.
Buzzbait said:Both steels are rather difficult to field sharpen. I actually tried to reprofile my Busse by hand once, using 200 grit wet/dry paper, and got virtually nowhere. INFI is very tough stuff, although it can work both for and against you at times. .
Actually I have found infi to be easier than any stainless steel to sharpen and about as easy as 1095 steel. But I think this is a matter of technique. some people do better than others at different steels.
Buzzbait said:The one nail in the casket for me, as far as Busse goes, was the ability of the knife to cut. Both samples I tried had very obtuse edge angles, and had far too much steel behind the sharpened edge, to be very useful. You could chop with them, but that was about it. Any cuts requiring more finesse than a full chop were pretty bad. .
Actually the blade geometry of a flat ground 1/4 inch thick battlemistress or steel heart with a 1.75 inch blade width has a better blade geometry than a saber ground 1/8 inch thick folding blade in my pocket. The two sharpest knives I have ever held were boh Busses. a BM-E and my 8 inch PBF. I also have a SHBM LE based custom shop blade that is scary sharp as well. The blade geometry is there and fine tuning the edge geometry is easy enough. These blades are far from sharpened prybars, they are good cutting tools. What samples did you try? did you own them or were they purchased by someone else?
Buzzbait said:In the end, neither brand won me over.
What kind of blades have you seen that you liked. I am interested in where your taste lies.
