Cliff Stamp
BANNED
- Oct 5, 1998
Few folders have tips strong enough for significant prying, you need 3/16" steel and little taper or the tip will give readily even in woods. The Howling Rat has about the slimmest tip profile I have seen which I would call heavy duty. The Tanto series from Cold Steel are fairly robust in that regard.tknife said:Point strength is the only real fault I can find that would make the Manix anything less than heavy duty.
Grease, lubricants are not a problem, however if you fill in the notch for the lock bar with dirt it can fail to engage, this is fairly obvious when it happens. A more functional issue is white knuckle releases, check the knife in your usual working grips and see if the lock can be accidently released.dino said:...lockback handle dirt, grease, ect..?
Yes, though not as easily as liners.Does anyone know if it can be closed with one hand?
-Cliff
