- Aug 21, 2014
I had that once. The cure was pennicilin in my case however...definite upgrade IMHO, brother...:thumbup:
but now you got "stripper fever"...
and the only cure is....more stripping!![]()
I used a belt sander with 80, 120, 220 grit. Then, 400 and 600 grit trizact belts. Finished with coarse then fine Scotch Bright belts.
Did the nooks and crannies with a small wire wheel on the dremel. It sounds like a lot but it really wasn't bad and I enjoyed doing it.
Its instant gratification seeing the progress getting better with each pass.
The last NMSFNO I stripped, the coating came right off and was almost perfect underneath. No decarb at all, the blade was just about satin and the flats were smooth and shiny. You never know what your going to get into when you remove the coating on a BUSSE.
After viewing this thread a few times I couldn't resist.
You made me do this:
Before
After
This one didn't go so well, the coating didn't bubble up and peal right off like the last one I stripped. I had to scrape it with a putty knife and wire brush. The whole thing Underneath was covered in dull grey decarb. It took a bit of work to bring it back.
Love how it turned out, am going to do the same thing..
Before
After
One thing that bothers/makes me think about stripping the blade.. Maybe it's just me being stupid but..
What if the paint stripper goes under the scales and makes the handlescales wiggly?
This thread makes me want to strip my TGLB though.
Strip away. The handle fasteners are pressed on with thousands of pounds of pressure.
Aint no stripper is gonna wiggle those handles.
Nice work guys.
Yeah I'm very happy with it. I probably will try to polish it up more doing what you said, but I also really like it when they look like users. Certain beauty about them. A tough i'll kick your @ss type of beauty!![]()
