Was curios how diamond stropping compound compares to stock colored compound that comes with the strop I recently received (strop newb here) I have a lot of higher end steel knives and have heard diamond compound works better. Any advice?
Diamond is at least ~3X as hard as any of the usual black/white/green/etc colored compounds, for starters. This means it cuts deeper, therefore leaving somewhat 'coarser' scratches than other compounds of identical particle size. On simpler steels like 1095 and 420/440-variety stainless, diamond would usually be overkill, removing more metal than necessary to accomplish the same end-goal. Diamond is at it's best in refining steels with high vanadium carbide content (S30V, S90V, etc.), because vanadium carbide is harder than any of the black/white/green and others. Cubic boron nitride (CBN) compound is about ~1/2 the hardness of diamond, so it'd work on these steels as well.
At very small particle size of maybe 1µ or less, diamond can more or less be used universally on most any steel. Care still needs to be taken on simpler steels though, because it's very easy to over-polish them with a small-particle compound this aggressive.
For most mainstream steels favored by knife nuts like us, black/white/green is plenty good. In fact, I tend to believe they're usually better-matched to mid-range knife steels from D2 on down, and can produce better results than diamond in most cases, as it's easier to fine-tune results on simpler steels with them. In particular, I really like green compound for 1095, Case CV, Opinel's XC90, 420HC. White works great with these as well, but also for others like Sandvik steels, VG-10, 154CM/ATS-34, 440C, D2 (these all have moderate to higher concentrations of chomium carbides, if you're looking for a commonality). Black also works well for most of those, but starts getting more aggressive with the softer/simpler steels; maybe a little more aggressive than necessary.
David
I see, s30v s35vn and Elmax are the steels I would be using it on, so it would be worth getting some 1 micron paste then? I have a good amount of s30v three s30vn and a couple Elmax.
That's the other thing there are a lot of different micron pastes so I should not go over 1 then?
With high-wear steels such as these, diamond will work better. And you shouldn't have to worry if you do go larger than 1µ. Depending on how much you want to refine your edges, they might be useful to you. For example, if you're wanting to mirror-polish your bevels, a tighter descending sequence of grits works better (such as 6µ > 3µ > 1µ).
I emphasized the 1µ as more universal overall, because it's not so large as to be a problem with softer, less wear-resistant steels (1095, etc). The combination of larger particle size and much harder grit can eat up low-wear steels much faster, and it'd be more difficult to fine-tune edges that way. The 1µ is still hard enough to work very quickly on these simpler steels, in spite of it's small grit size.
David
Ok one last question. Just for reference, where do diamond and boron nitride compound fall in line with the grit count on the stones/polishing tape and normal stropping compound? Right in between?
And how does the scale of microns and grits relate? Sorry I'm sure I could google a lot of this but the advice I find here is very direct and is automatically cross referenced by other members who view this thread, and so far your advice has provided the exact answers I was looking for, much thanks.
The strop I use with it is a simple leather over wood thing from Tandy, also bought off of Amazon.
I'm pretty sure green compound is usually Chromium Oxide with a mean particle size of 0.5 micron. White rouge is usually 1.0 micron.
I use green on suede and plain leather after I finish sharpening on ultra fine ceramics. Hope this helps.
Do you sharpen your convex blades on the ceramics and finish with the strop? That is the big reason for me getting into stops recently. Just acquired some new blades with convex edges. I was thinking about 2 two-sided strops. One with black compound and one a bit more abrasive (if there is any) on the other side, and the other strop with green on one side and bare leather on the other. I want to maintain the edge!
Among the commonly-used trio of black/white/green compounds, black usually is the most aggressive; the sequence usually goes black -> white -> green (then to bare, if desired). If you're wanting to make and use a couple of two-sided strops, a logical combo would be black/white on the first, and green/bare on the second one. Start at black, and go from there.
David
Do you have any idea where a 4 micron CBN emulsion would fall in the black - white - green steps?
