Strop compounds - New Member
The black Ryobi 'Emery Buffing Compound' I have is listed at 1-3 microns, as labelled on the tube. It applies much 'coarser', as the hard/waxy binder is very clumpy/chunky; sort of a pain applying to softer surfaces like leather (I use it on paper over glass/wood). Once in use, though, it's very fast in cleaning up the scratches and finishing at near-mirror, more commensurate with it's rated grit size. Reminds me a lot of the 1µ & 3µ diamond pastes from DMT, in that regard.
(HH's post above does remind me, a lot of the black compounds are indeed emery, a.k.a. naturally-occurring aluminum oxide; also known as 'corundum'.)
David
If you are having trouble using the hard or chunky stuff, just put it in the microwave for about 5-10 seconds. It will smooth right out for you.
Stitchawl
Stitchawl
My 'chunky' compound & I have come to an agreement now, and we're getting along better. :D
I've been using it on paper-over-wood (sometimes use textured paper), and it's easier to apply well enough that way. The harder-backed paper scrubs it off the stick more aggressively, and it also seems to embed into the paper better. Works great too.
David
How to turn chunky' compound in to liquid compound
Thanks
Assuming this is a question(?). If so, it can be softened (at least) by warming it, as suggested by Stitchawl. Some have also used a little bit of mineral oil rubbed onto the stick or the stropping surface to soften it as it's 'crayoned' onto the strop. I think that's generally the easiest way, when applying it to leather in particular. WD-40 could be used in the same manner. Not sure it can be liquified easily, due to the waxy binders in it. Maybe by heating to a higher temperature and mixing/pressing/grinding it to break up all the chunks, though that may not be worth the extra trouble. Softening it and crayoning onto the leather, just by warming it a little, or using a little oil/WD-40 as described, is much easier.
David
Grits and Microns?
Bark River Knife compounds: black (3,000 grit), green (6,000 grit) and white (12,000 grit) sharpening/buffing compounds.
Very helpful, thanks! I have some of the green and black compounds from Bark River on their way in the mail, but I couldn't find their grit equivalent anywhere. Thanks again!
