- Dec 20, 2009
Here's a subject that is mysterious to many people. Why do materials move? Many natural handle materials move, some more than others. No matter what you do, cure it, dry it, stablize it, pin it, substrate it, glue it, captivate it, and seal it and it will still move. We as knife makers go to great lengths to keep expansion and shrinkage to a minimum but with some materials in some climates they will still move. It has been a recurring subject on this and other forums, in some cases (not so much here) it is with quite a bit of venom toward the knife maker or material dealer.
Movement occers, for the most part, due to a change in moisure content in the material, and to a lesser degree a change in temperature and I am pretty sure, though I have no proof, a change in barometric pressure. Fine furniture makers have known this for a long time. The effects can be mitigated in most cases by the methods mentioned above, but some materials were just not meant to be used on knives in some areas. You can do everything right and some materials will still move in some areas.
The average indoor humidity in Fairbanks in the winter is about 8%, so if I send a piece of handle material that has been cured properly to a maker with a humidity around 30% the material will need several months to acclimate to the new climate before it is used. To further complicate matters, if the knife is made and sent to an area with a different climate it will move again, and if it is an area with huge fluctuations in indoor humidity the material will continue to move forever with the seasons. A knife could have no apparent problems for many years and then all of a sudden shrink, expand or crack, especially if, but not necessarily if, moved to another climate.
As I mentioned, some materials are worse than others, horn (maybe musk ox horn especially) and ivory seems to have the most problems. I have spent a lot of time trying to figure out solutions to these problems, I have learned a lot but, still don't have all the answers. I have knives with exotic materials and technical assemblies all over the world and have had just a few problems. I am sure that I will be repairing knives every once in a while for as long as I continue to use exotic materials, I think it is worth it. I am willing to help other makers if I can.
There are lots of fine knife makers and material dealers, the thing to keep in mind is if something goes wrong with a natural material, it doesn't necessarily mean someone did something wrong. Pick an experienced maker, follow his instructions for care, let him know if a problem crops up and he will do what he can to fix it, no sweat. If the thought of something happening to your knife bothers you too much, stay away from the exotics.
Hope I didn't come off as some kind of know-it-all, just one man's opinion. Thanks Mark
