- Dec 31, 2008
I pounded the tang into the handle without epoxy and now I can't seem to get it off. I tugged on it hard and it didn't budge. Any suggestions?
I'm contemplating just leaving it stuck without epoxy. I think it would be plenty strong for average use seeing how I can't even get it off pulling on it as hard as I can. Mind you, this isn't going to be sold... it's only my 4th knife. I would break the handle off but, I really like the wood I used and like I said, it seems strong. What do you think? Maybe I'll just put a pin or two through it.
Wrap the blade in a rag or piece of scrap leather. Clamp the protected blade in a vise and pull on the handle (brace bench with your foot as required)
If that still doesn't work, get a piece of 2"x2"x12" wood (or an appropriate size for your knife). Cut a slot in one end of the 2x2 length wise about 3" deep and as wide as the blade is thick. Clamp the protected blade near the tip end in a vise. Slide the slot in the wood over the blade close to the ricasso and hold the loose end of the wood in one hand while hitting the wood close to the ricasso with a hammer.
Brad
www.AndersonKnives.ca
It will come loose i promise. I did the same thing with a hammer i made and i had to use a 20 ton press to get it on and i maxed out the press. I told my self ya right it will come off. after a little forging i looked and the head was almost off the handle. now a hammer does take a lot more of a beating then a knife but wood will swell and shrink and it will come loose. it's worth it to try harder and get it off. with out seeing a picture i cant give any advice on how to do that.
