So to summarize this discussion(or my questions/confusion anyway), and the papers I've been able to find and read online, with the fewest acronyms possible:
- Sub-Zero (-100F) treatment is required to eliminate retained austenite (RA) and finish converting it to martensite (Martensite Finish temperature, Mf) in high alloy steels. This has little effect on wear resistance compared to tempering without Sub-Zero treatment
- Cryogenic (-300F) treatment is required to precipitate "eta carbides" which enhance wear resistance. (Can someone define "eta" I cannot find this anywhere? Just Fe2C?)
- We don't know which alloys will precipitate eta carbides, it's assumed they're created in higher alloyed steels but some steels with higher alloy like AEB-L do not seem to form them? (Performance based evaluation or some other means of determining existence or lack?)
- The book is still out on whether cryogenic treatment and eta carbide precipitation lowers toughness when compared to High Temper Temp (HTT) alone? (referencing a post Larrin made in 2016 and a paper on carbide formation in carburized steel) Or is this more alloy dependent?
Nothing I've read here or elsewhere has given me any confidence that cryogenic treatment is always desirable, or, if not always, when it is desirable, outside of known/tested heat treat procedures such as the 3V Low Temper Temp procedure.
My ultimate two questions being: Is it beneficial to simple steels (1095) and if it is, at what cost if any, and by what mechanism? And 2, would cryogenic treatment of S-7 increase it's wear resistance without lowering it's impact toughness?
Both of these I would test on my own if I were set up for cryo. But the answers to the questions impact my decision of whether to invest in cryo or not. And while I previously adhered to JT's posts about "everything in cryo" if only because it's easier/cheaper than doing both cryo and sub-zero one's self, now I'm questioning whether everything in cryo has some negative impact on some alloys in regard to impact toughness.
