- Jan 28, 2010
I just started convexing on a couple select knives that I wanted to try a different edge type. I went from 80 grit for reprofileing down to 12000 grit. I was wondering if I will get any benifit from using a compound on a strop? Most of the compound I have seen are almost the same micron size as the 12000 grit sandpaper, as far I know it should be around .50 to .60 micron. I am not positive on these fiqures however. Are there any finer compound? Should I just go to bare leather after the12000 grit?
A good compound applied to the flesh side of a strop glued to a block of wood. With sandpaper you will allways have micro-serations. I just bought the green compound and the block from I forogot where. But if you want the name PM me cause I have it in my favorites. You pass your thumbnail on a knife, uh um excuse me I see you are using 12000 grit. I do not know where you are finding this grit of paper. The best I have done is 2500 grit and really had to search hard for that, maybe you mean 1200 grit. Any way after my 2500 grit I use the compound and strop, and the edge is smooth. You can run your fingernail on top of the cutting edge and you get the same feel as a razor blade. You feel nothing at all. And it does make a difference from using just the flesh side of a strop alone. A big difference. Slice paper like it is not even there.
Any way the compound is green and if you want the site I bought it at give me a hoot. And if you really have a source for 12000 grit please pass the source on to me. Great for refinishing old blades and make them like mirrors again. But my 2500 does that already.
But I just want to add. How sharp is sharp. What do you want to do with your knife with such a keen edge surgery on someone. Just my toughts but like one persons handle says " Obsessed with Sharp" or something like that. And that is exactly how I see it obsession. But really if you do find paper finer than 2500 I want to see a source, after I just insulted you LOL!
Kind Regards,
Daniel
