- Oct 30, 2001
I use a spray bottle with water while drilling ferrocerium. It not only cools, preventing sparks, but it lubricates, resulting in longer drill bit life.
Mikel,
I just use a new (sharp) HSS drill. I ussually start with 1mm and go up to 4 or 5mm depending on the firesteel thickness.
I just drill slow speed and stop to add a drop of water after a while. Just to keep the shavings wet. When I have a pile of shavings, I remove them to prevent combustion........
CZ
My main problem is that I don't have a drill press so even clamping down the ferro rod tight so I don't need to hold it, I am running out ouf hands to use any kind of Spray bottle...![]()
I may just ask for help to someone else to spray it with water next time. What kind of drills do you guys use?
Mikel
