Fred.Rowe
- May 2, 2004
No, it's sad, but I made a foam box for it and her wrists are getting better.![]()
A wize choice :thumbup: Moms are hard to come by; sanders are replaceable
I followed Fred's ideas. I had two 3 or 4" thick pieces of dense foam. Pierced a hole thru the center of one and pushed it over the palm grip up to the bottom of the pad.
The other pad sits under the inverted sander, then the whole thing was pushed into a cardboard box. Tight fit. The sander doesn't touch anything except the foam.
The switch is covered up, so it's switched on. To turn it off I just pull the plug.
Covered with 400 grit wet or dry it sands and cleans up the plunge shoulders in a minute.
Thanks a million, Fred.![]()
I'm trying to set this up.
Can the motor "breath" or is the palm part stuck in foam?
My instructions mention that it can get very hot...
The air holes are exposed in the top layer of foam, but are enclosed by the bottom layer.
I'm not going to worry about that. I probably use it a few seconds at a time.It works so fast a few seconds is all it needs.
I am resurrecting this post to see if anyone could post a picture of what this set up looks like. Thanks!
I have heard of using one of those 1/4 sheet palm sanders before but this sounds like it might be pretty cool. Can not wait to see the pictures.
