There's sharp as in after a sharpening. Then there's a working edge. A middle time during the wear of the edge. That maintains a level of sharp.
Different steels take and hold a working edge. Different then each other.
I've used this comparison before but consider the razor you use to shave. At first, it's too sharp. You end up nicking yourself. Then as the blade wears. It's perfect. It'll shave hair but won't bite into the skin. Then as you continue to use it. All of the sudden, the working edge stops shaving hair. It's still sharp but the working edge has been worn past, the needed amount of sharpen to do it's purpose.
Same with kitchen knives. Some folks are terrified of a razor kitchen knife. But once it takes a working edge. Then they use it. Only stopping, after it gets, 'dull'. For which is subjective to the person using it.
The working edge of s20v will be different then 1095. However, to each their own. One person might prefer the working edge of 1095 over s20v. With both being the same level of, 'sharp'.
