- Dec 27, 2013
2400 degrees even with a semi brine quench will not drop down to martensite, I did cross section cuts and stock removal just to check for case hardening, isnt either and all martensite will shatter without a temper, I beat the hell out of this thing trying to break it untempered and it doesnt break. 3 hours is enough to get over the curve at sustained temp. the material is also through hardened and there is only ONE pitch tone and no resonance. very very short high pitched sound with no lingering ring or vibration. Martensite will resonate and continue to do so. It has deviant physical properties abnormal to conventional heat treats for spring steels. I cant claim to know what exactly it is but I know what its not.
Im in the process of occasionally trying to replicate the process with a very thin casing of satanite filled with grainulated charcoal and a piece of steel sealed in the canister.
I haz a question, not being a smartass either: how did the pile of charcoal with air blowing through it for three hours maintain a constant temperature and atmosphere without adding fuel or tending to it? I don't use charcoal, maybe it lasts longer than I think. :[
