- Sep 29, 2008
THis is one of the major drawbacks to nearly all of Surefire's line. With few exceptions, Surefires must be powered by one or more CR123 Lithium cells. These are a great power source, however, they are not generally easy to find and when you do, expect to spend anywhere from four to eight bucks per cell. (If you shop the internet, you can do much better than this... but don't expect to find replacement cells at your local drugstore and if you do... you'll pay dearly for them!)
And the problem with lithium cells is that each time you use the flashlight, the battery become weaker, so over time, you will start your day with a flashlight which has a semi-discharged cell. In time you can do nothing but discard the depleted expensive cell! On the other hand, with other brands/models which can be powered with rechargeable li-ion cells, you can top the cell off at the end of the day and always start each day with a fresh cell.
Um, that's how all batteries work unless they are rechargeable. Surefire lights can run on rechargeable CR123 cells.
And for Surefire models which use two lithium cells, you MUST make sure the two cells are very well matched to each other... for using a fresh cell with a partially or fully depleted cell can result in a very dangerous lithium venting "event" which can cause severe damage, injury, and/or fire. This is serious stuff... we're not talking about your grandpa's harmless alkaline batteries here.
This "venting" and "severe damage" only results in batteries without sufficient thermal overload protection, such as those made in China without proper quality control.
This is the major reason why I don't use my Surefires very often. I prefer to use brands/models which can be powered by rechargeable li-ion cells, rechargeable NiMH cells or even, if no other option is available, the lowly AA alkaline cell which can be found pretty much EVERYWHERE, no matter where you are.
Practically every Surefire flashlight must be powered by a CR123 Lithium primary cell. This is an important point you should not lightly overlook. Lithium cells are the cells of the future... they pack a lot of power in a very small space and have a very long shelf life, but they have some noteworthy drawbacks as well. You need to understand flashlight powering sources and options well before venturing into this realm.
Don't get me started on buying lithium cells in a brick and morter store. Several wanted upwards of ten dollars each. Ridiculous. That's why I always have spares.
