Hey ya for all who are interested my tip went down two weeks ago and it went terrible. the first thing was that the way i heated my shelter i used a lean two and a fire with reflector.
Try an a-frame next time that's just big enough for you to get into with ~1 foot thick of pine boughs on the floor, they're quite comfortable (I preach this one left and right, it's one of absolute favorites). They get real warm (keep in mind I'm talking as compared to freezing to death), snug & dry when you block off the opening. You don't even need a fire at that point, your body heats it up by reflection and insulation.
The classic lean-to isn't good for much except a rain braker and shade. The three open sides let wind in every which way. Even if you close two of the sides off, you still have that big, open front. With no fire you'll still chill and maybe even freeze. (I stopped using regular lean-to's after my first time out. By the second day I was saying to myself: "F--k this, there's gotta be a better shelter type")
I still use a lean-to, but it's usually only in the warm summer months when I know the nights won't freeze my ass off. Even then I still have a fire going and a pine bough bed about 6 inches thick.
but the wood was way to wet to burn and nothing big just little stuff about the size of your thumb.
Fiddley had an excellent point about this. Standing wood is your best chance for dry wood, even then you may have to split it. Anything on the ground is bound to be soaked.
Once you get a good fire going, if you have any damp wood, split it and lay it near the fire to dry out.
next was the water the water after being boiled was terrible i mean gross so i spit it out and used tablets and still gross tasted like bad eggs.
Sounds like it was full of Sulfur. Did it smell that way BEFORE you boiled it (like it was full of rotten eggs)? Filtering through a bandana would only remove large particles and sediment. Charcoal from a fresh fire would more than likely have worked in a three tier system, but you said you barely could get a fire started. Your best bet would have been rain collection or to find a puddle somewhere and get what you could from that, then kill it.
so what am i going to do i am going to do it again in a different area in two or three weeks just though i let you all know
Sounds like you had a fine area right there, just wet and crappy water. I'd use the same one and just find a different way of getting H20 (taking some with me for back-up of course).
You gave it a try and didn't get discouraged, that's the important thing. That shows you have enough guts to push on in a real situation. :thumbup:
The important question is: Did you LEARN anything?
