Take Down Fighter Work In Progress
Josh, after seeing ALL the painstaking work on the knife, time and effort taking/arranging/describing the photos and of course loss of flesh, I almost feel I own you more money. ;) :D :) Thanks Josh.
Here are all of the parts of the handle ready to glue up.
I take gluing in baby steps. No sense in rushing at this point. I use 5 minute epoxy. Here I have glued the liners to the frame with the blind pins in.
Once I've done that to top and bottom I then glue the ivory scales to the frame.
While that is setting up I am going to make the stainless name tags. This is something new I've never done. Usually if I do something like this I will make a sterling or gold collar that slides over the tang and blade. This will be pinned on.
Drilling holes in stainless.
These have to be filed down to the shoulders of the blade. This is a major pain because you have to file the sides along the face of the guard too.
Laying out pattern.
Hammering the pins down hoping not to see a ring or damage the finished blade.
Mushroomed pins.
Now they have to be filed down and the stainless pieces have to be mirror polished. Before I do that I do one last check on my guard fit and squareness.
Check payable to Josh Smith
Box 753
Frenchtown, MT 59834
Now I am laying out my name for etching.
Etching Name.
At this point all of the parts that are Damascus are etched and finished to my liking.
The guard is then fit into place and typically I will place a small amount of JB Weld around the back in the gap that was milled in it. This is a vapor barrier. I don't ever put anything around the front of the guard. That is what all the time spent fitting was for!
Now the tang is wrapped in Teflon tape and coated with vaseline. I am now going to bed the handle in epoxy. All of the space in the handle not occupied by the tang will be filled with epoxy. Once this is done the need for the blind pins into the front of the handle will no longer be a necessity, though I still like to have them just to make me feel good.
I'm sorry no picture were taken of this but when you mix the 5 minute there is NO extra time. I will explain.
I taped off the hole for the finial and filled the handle with glue. I then slid the tang down in letting epoxy squeeze out. All parts were coated in Vaseline that way the epoxy would not stick where it wasn't wanted.
I then let the epoxy set up hard. At this point to blade was clamped in a vise and the handle was pulled off the knife. I'm always nervous hoping I didn't miss an area with the bag balm! That would be bad.
Here's a look at the pocket that was left.
At this point I turn the handle around, take the tape off and mill and drill out the glue in the back of the handle just a bit until I find where the end of the tang was. This gives the finial room to slide in and thread on.
Once this is all done I epoxy the escutcheon plates into place.
I then make sure everything works well, sharpen it, and make a take down tool.
It's hard to see the mirror polished name plates because it is reflecting the guard Damascus pattern in them.
Here is a shot Kevin had Coop take at the Blade Show. Nice job Coop.
I'd like to thank you all for tuning in. I appreciate the compliments and I hope you enjoy the finished product. Thanks Kevin for giving me the opportunity to make this knife. At some point I'd love to do another one of these WIP's...but it will be a while!
Thanks again everyone,
Thanks for taking the time and sharing the knowledge.
Have the best hammer in yet, Craig
What a wonderful ending! Thank you for taking the time to do this Josh, it is much appreciated.
Did you epoxy the butt and spacer to the handle as well. or are they seperate components when taken down?
Also, I am curious as to the threaded rod size that you used on the tang?
Thankyou again -- Have a great hammer in this weekend!
Brian
Excellent thread, Josh....
ALL WIP threads of this detail are helpful for everyone from non-knife person to the greatest of enthusiasts.
Kevin, you should be very proud, I know I would be!
Best Regards,
STeven Garsson
A picture is worth a thousand words Josh and you provided many in this tutorial. I have read of many techniques and processes associated with fabricating intricate take down pieces.....but until you see it done.....your only imagining the steps. Your time and effort with this learning experience has been invaluable to me and many others.
Thanks so Much!
Bob,
P. S. Perhaps a sub-hilt DVD is in your future? I know I'd buy it.
This is the best WIP thread I've followed. The finished knife is breathtaking Josh. Thanks much for taking your time to show us your work. Very enjoyable. See ya Friday.
Absolutely stunning. Thanks for pictures all the way through the process and the information.
真的好棒的製作過程.
我都有記錄起來.
對了.她有刀鞘嗎?
