Absolutely, do an anneal or sub critical anneal and then redo the HT.So, anybody knows if I can redo the HT ?
Thanks,
You can re-do the HT . but I doubt the blade is as soft as you say … unless it wasn't hardened right.
As noted by Richard, a 525°F temper would only drop the blade to around Rc58.
Questions:
Does a file skate a bit on the edge or does it just file away the metal?
Was the clay too thick and too close to the edge?
What temperature was the HT done at?
How long did you soak the blade at targer temp?
Yes, the file skates a bit on the edge.
What I did different this time, I put 3 cots of ATP-641, instead of 2. But that’s pretty thin I think.
I brought the oven at 1475F, inserted the blade and held for 30min. The oven got back to the target temp in 5min. Say it took another 5min for the blade to come to 1475F. So it soaked for at least 20min.
Just for clarification, since there are no parallel surfaces left on the blade, I measured the harness
on the bevels that were left at 80grit.
Maybe the combination of inclined and rough surface gave me such an erroneous reading?
I understand it is not ideal to take the measurement as I did, but I didn’t expect to be off that much.
What do you think I should do at this point?
I could perhaps make a coupon leaving a flat area and also grind a beveled area on it, then HT the same way and measure hardness on both surfaces.
Thanks again,
Constantin
Makes sense, thanks !In my experience, measuring hardness on either inclined or rough surfaces will give pretty peculiar results. Not trustworthy at all.
Great, thanks again!On my katana I followed advice from Stacy and did a flat grind down to around 0.02", then convex to nothing. It is one of the easiest grinds for me. I did some final sharpening on a big diamond. Ended up very sharp and no secondary bevel.
Haha, that’s strange though. My O1 even at 65 HRC isn’t hard to hand sand at all. Are you using good paper?LOL, it must be hardened, cause I’m definitely sanding my ass off...
Yes, I’m using Rynowet, but I don’t really like hand sanding and so I whine about itHaha, that’s strange though. My O1 even at 65 HRC isn’t hard to hand sand at all. Are you using good paper?
Stacy E. Apelt - Bladesmith , i’m working on the handle.
I have a question about the hole in the handle.
Should it be a bit offset towards the end of the handle relative with the hole in the tang? So that when inserting the tapered pin it will pull the blade in, locking it better ?
Also, is the pin inserted from the left or right side? (While pointing the blade forward)
Thanks again,
Constantin
