I paid $18 for it, and I guess maybe it is worth that.
The wood looks very nice. It is larger grained than the old real LB7 I have, but is finished nicely.
The wood is about a hair too small all around, not tightly fit to the bolsters.
The seam between the bolsters and liners is visible. The real LB7 I have it looks almost like it is one piece.
The spring is integrated with the spacer, not a seperate spring bar set into the spacer piece like on a real LB7.
IT IS BLOODY IMPOSSIBLE TO UNLOCK THE BLADE USING ONLY THE APPENDAGES I WAS BORN WITH. I have to push it against the edge of my desk to unlock it.
On the plus side, the lock bar, handle, and blade line up perfectly when opened. But that's easy, all you do is open the knife after assembly and grind down the back. Not so good when closed, but not worse than I have seen a few real Schrades and a lot of Bucks.
I will try to do some tapping on the spring to weaken it and see if it can be made useable.
No testing yet for sharpening and edge retention. If I can't make this piece of junk work, I will still be able to test the Chinese sharpfinger I also grabbed.
