- Nov 7, 2004
Good description of a fine knife, Elen. Not much to add to that.:thumbup:
And it's no wonder! I love that one. Is it a custom, or is there a website that sells that knife?
"For me, the down side is that they don't cut nearly as well as a flat ground knife that has the same width and thickness. The "scandi" grind is basically a saber grind with no secondary bevel. It is very easy to sharpen, which I suspect contributes to it's popularity."
cut what as well? cardboard? a flat grind does not have the shoulders that get in the way when cutting cardboard like a scandi. scandis excel at carving wood, where the wide bevel allows a great deal of control. the right grind for the right cut is what i always say.
I bought that from the smith himself, and I haven't found a web-site that sells this knife. I did saw some on a Finnish hunting show a couple of years ago. I also found Kivimäki's contact information from the web, so I'm sure he still makes knives.
I posted a couple of pics of this same knife to an earlier thread:
http://www.bladeforums.com/forums/showthread.php?t=528030
Could you please tell us more about the different kinds of scandinavian knives. There are puukkos (sissi? tommi? väki? ...?), leukus, hukaris, probably others. I'm very interested in those knives but it's all a world, where to start? where to go? I'm not a collector, just a user, my main concern is woodcraft.
I can't tell the difference (or don't *know* the difference) between a "puukko" and any other Scandi-grind blade.
Elen, or others in the know...what would a "real deal" handmade Puukko cost? Nothing fancy, curly birch handle, 4 inch blade, leather drop/pouch sheath.
What elen and others aren't telling you is that a "true" Scandinavian knife doesn't have a guard, in fact, it doesn't even have scales! It is a sharpened scandi blade from tip to tang!Only a truly "skillfull" woodsman can possibly yield one, certainly no one from North America!
- FLIX
That was a long way of saying there's no definitive answer.
In this post i refer to a traditional blade with a single slightly hollow grind as Scandi grind. (allthough i know there is both flat and flat with a secondary bevel scandi grind )
Someone once asked me the purpose of a single bevel, and if the single bevel only stayed on untill the first sharpening. I have beene giving this some thoughts, and here is what i have figured out
When sharpening scandis (remember slightly hollow) you can not sharpen the whole bevel, cause you are into some heavy work making the grind flat. You will be able to just sharpen the tip of the edge for quite a long time before you get a secondary bevel, this is due to the fact that the grind is hollow, and thin not only in the edge, but for maybe 2-3 mm into the blade.
When you reach the point where the edge is getting thicker, and you find that to get a sharp edge you have to make a secondary bevel, you must re-grind the blade, once this is done you have a brand new bevel witch you can sharpen 2-3 mm before you have to do a re-grind.
As the blades are fully quenched you are able to do this untill there is litterarely nothing left of the blade. (witch takes a really long time with what i presume is your needs.)
