- Oct 1, 2011
Happy Thanksgiving!
Looks like the only thing on the menu is DEAD HORSE though...![]()
Great comment.
Happy Thanksgiving!
Cool. I'll stick with my statement still. If people want to claim that their Emerson knife is meant for hard use, not basic cutting, then give examples such as using it as a prybar, then they should have bought a prybar and a box knife. Would it make you feel better if I said a $10.50 box cutter? $100.50? I know an Emerson cuts a bit better than a standard box cutter, but I know it doesnt pry or punch or melt steel any better than any comparable knife in its price point. It also doesnt kill terrorist leaders any better, it doesnt conduct "Close Quarters Combat" any better, regardless of the number placed after the acronym, and it doesnt induct you into an elite group.
Its a folding knife, it does things that other folding knives at that price point do, som at that price do things better, some dont. It doesnt do anymore.
I am a bit put off by Emerson and his marketing. Given the pricing, his statements/marketing, and their availability I probably won't buy another one anytime soon. Then again I don't buy very many knives.
Knives aren't really meant to pry and I'm sure an Emerson will break if you really try to PRY with it.
imho, if you don't need the wave feature, don't get an emerson knife. I have 5 Emerson knives, and have used the Cqc7. I end up selling the used knife and keeping the rest for collection. As someone mentioned earlier, there is no sweet spot that i can adjust to flick the knife out without having blade play or having the closed knife open up itself in my pocket while i am running. So there's only 2 ways to open am Emerson knife is to slowly use the thumb disc, or to wave it. Thus, if you don't find the need for wave, there are many other options.
Knives that i highly recommend: ZT 0200, Benchmade bedlam, Spyderco paramilitary2, Galye Bradley.
How does that happen?
Like he explained in his post.
Either loosen the pivot so you can open it with your thumb, or tighten it so it doesnt open in your pocket. Poor design.
Mostly they suck...locks stick , blades loose and off center....piss poor quality (IMO)....the wave feature is cool but thats about it.
I know it sounds like unnecessary work, but you can get the blade reground from the double-v chisel, to a conventional edge.
Then you get Emerson ergos and designs, plus a blade that cuts straight.
Your choices of the Paramilitary 2 and Yojimbo 2, do demonstrate how Emerson knife quality should be.
Agreed, even some of my customs will stick. Though Kershaw has been doing better in that regard as my 0301, Speedform, and Tilt never stuck.I suppose you're claiming you tried most of the Emersons out there...
yes, the lock sticks. just like pretty much every other lock using titanium.
Agreed, nothing a little loctite won't fix. Though some knives seem to have been pre-adjusted and already have loctite applied. At least, I assume so, I haven't had to adjust the pivot on my last 20 knives.the pivot does loosen. just like pretty much every other pivot using a screw.
Centering wasn't an issue once I tightened the pivot.every single Emerson I've had showed perfect centering. naturally it'll look off to the side at the tip due to the chisel grind.
I hate to say this, but my thumb had the skin repeatedly torn off from repeated use with my Spyderco Moran. Some insist it's there for striking a firesteel, but I could do without it. As for the screws, I did mention that some companies are starting to loctite their screws. Spyderco and Kershaw seem to threadlock ALL the screws, even for the pocket clip. Thus attempting to remove the screw without warming it up to break the loctite will result in a stripped screw. As for Emerson, every screw on the knife seems to loosen up over time without loctite. Nothing big mind you(aside from the pivot), but it'll happen.piss poor quality? not even close. there are many things other companies do better, but there are some things Emerson also does better. For example I seem to have to take a sandpaper to every Spyderco knife's spine nowadays because they come almost as sharp as the edge. My G-10 Delica has SS liners also as sharp and it's one of the most uncomfortable knives I've ever used. Of course one of the screws stripped while trying to disassemble the thing to sand it. I've never had such problems with any Emerson.
I have to admit, the mall ninja in me was not looking for a chisel grind for that reason.I did say myself that Emerson's left handed chisel grind doesn't serve much use, but thinking about it, it would be better in a regular slashing motion, as in you have the knife in your right hand and you are slashing right to left. Most EDC cutting involves left to right cuts for right handed people, and I really can't think of uses for right to left cuts except for offensive/defesive slashes and chopping a tree down. So in that respect the left handed chisel grind serves a purpose. Unfortunately, any kind of edges do fine cutting into soft flesh.
Off-topic, distasteful content removed per member complaints
Tom...Holy Crap!
srsly, a poopbubble...
Thats freakin disgusting:barf:.
Why did you post that here?![]()
