Eric_Draven
Banned
- Aug 16, 2002
Cliff:
I disagree, when the edge is so obtuse that the knife can not efficiently cut any material, than it is too thick, period. If you have atask that requires such a thick edge, than a knife is simply the wrong tool. A knife is meant to cut and slice, and if large enough chop. When you are talking a very high grade of steel like INFI coming from the factory with 50+ degree edges, there is no possible reason, except for cutting bone or hardened metals.
Busse uses, and heavily promotes, the toughness and strength of INFI, but if the edge is ground thickly, that is no accomplishment.
Even a paki-crap mystery steel knife will withstand tons of abuse if left at the thickness that Busse leaves his.
People are spending over $300 for a knife and it does not perform at the level that it should, and not even close to the level that it is capable of.
Putting a proper edge on a wear resistant steel like INFI is time and labor consuming, it should not be left to the customer.
Yes, Busse may do it on a custom basis if you ship you knife back to him, but now you add the total shippping costs, plus any fees he charges for refinishing the knife, etc. and you are talking money that should not have had to be spent to get the knife the way it should have been in the first place. In addition, as a Canadian, you should be especially concerned with duty,a nd international shipping issues. Sometimes sending the knife back is just too costly.
Just compare a NIB battlemistress to an ABS class blade, the difference in edge geometery (and primary grinds) is on another level, the resulting performance is beyond comparison.
Jerry has now defined extreme performance as meaning that Busse knives excel at "non-knife" functions like prying.
Only sharp knives are interesting.
Also a $5 dollar 9" carbon steel kitchen knife (like Ontario) makes a far better machete than your battle mistress, try swinging that huge hunk of steel through grass and vines for a few hours, when you arm falls off, tell me how effective the BM is then.
Also, try using a 9" blade to clear some paths through briar patches, black berry bushes and hazel, then explain how the factor of reach can be so easily ignored.
Someone better head down to South America and tell all the indigs that they have been using the wrong tool for hundreds of years. Those fools have been using machetes to clear jungle, clean fish and build houses since the spanish invasions (the machete is dirivative of the spanish cutlas). Jeez, just think what they would be able to do in the jungle if they had a 9" long, 1/4" thick piece of thick edged steel they couldn't sharpen!!!!
As Matthew Rappaport has in his sig line:
The difference between theory and reality is that in theory there is no difference, and in reality there is.
Bensano:
Yep, check out this thread:
http://www.knifeforums.com/ubbthrea...185737&page=0&view=collapsed&sb=5&o=7&fpart=1
An edge can't be "too thick" or "too thin", as geometry is task specific
Bensano:
A GB small forest ax will cut down trees better, AND cut up vegtables
