- May 19, 2003
My only question so far is when do you lap the holes?
Before or after the HT?
In 1941 the Battelle Memorial Institute published a book, "Tht Prevention of Fatigue of Metals" for the US Naval Ait Command. In this book they describe the stress raisers emmanating from round holes in metal.
Your discussion intrigues me, have any of you noticed methods of drilling holes that weakened the metal to a more or less degree than others?
..........I whole heartedly agree with JCaswell about honing after HT. The hole will change size during HT. If you hone before HT, then the hole will not be the correct size after HT. Honing after HT is the Standard practice in industry.
One other thing that will make it difficult to hold a tolerance of less than .0003" is the runout tolerance of the bearings in your drill or mill.
Next time you check out the drill presses in your local stores, run the shaft down and see how the play is. Was stunned at how sloppy many of the higher end drill presses were!!!
