- Aug 31, 2010
I wholeheartedly agree, proof is in how many I have acquired in two years and that I have my EDC2 on me now. Still think it’s funny though.
Where can you buy the the platen/chillers?
Nathan, how're you doing on this fine Monday before Thanksgiving?
Ugh...those kinda days are disheartening to say the leastToday was one of those days where I'd have got as much done had I simply stayed in bed...
Thx for your reply. When you do. Do you have a way to sign up for one. Thx.I'm sorry, we don't have those available at this time.
Hey Nathan,
I finally received the double edge fighter. It is amazing, the grip is quite different than the Pig Sticker's grip.
It's the first kydex sheath from you that rattles with the knife inside. Is it normal? Because the knife is double edged?
Nathan, the Lengthwise Grinds on the UF's (via Instagram) look amazing
My Question is this: I am assuming the DEF's 's will have the same lengthwise Grind?
And how much more difficult was to achieve the Lengthwise Grind?
They Look Amazing
Tom
Hey Nathan,
I don't really know what constitutes normal, I'm not a kydex sheath expert <--- which is why I colaborate with one of the best sheath makers in the busness. I like the fit on mine just fine (and if I shake it, it will rattle, I just don't care) but if you don't like yours you can return the knife for a refund, you can send the sheath to Eric for adjustment or you could tweak it yourself to your liking. Personally, for me if the fit and retention is good I don't mind a little play if it means it doesn't drag as much on the blade so I previously have made thermoform tooling to have clearance on the blade and grip the knife by the front of the handle. Eric does all of his own tooling and adjustments so I don't really know what his criteria are. I'm sorry if I can't really answer your question. Please let me know if there is somthing you would like me to do for you.
Return the knife? No way ; )I don't really know what constitutes normal,...
Interesting, do you know if the UF and DEF sheaths are the same, or is there a slight difference?FWIW, my UF and DEF both rattle a bit, ...
