Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
Nathan, when and what for will you next use Aeb-l?
I was thinking a kitchen knife maybe
Is there a pic of the IP micarta you described in yesterday’s sale? Trying to decide what to put on mine. Didn’t see it in the encyclopedia. Thanks! And sorry if this should be posted elsewhere
I just peed a little....I was thinking a kitchen knife maybe
Since I've already gotten my SHIV 2.0 !... I'm all for a 10 inch chopper pre-order !!!...so I hope the chopper is the next one up since we haven't seenI don't really know the answer to this one
I could do a pre-order for the EDC or the 10-inch chopper right now, but I'm getting pretty late delivering the Shivs so I don't think I should start a new pre-order until that one is done.
A chopper pre-order for some years now but we just had a run of the DEK Series, The SHIV 2.0, The K-18 and the K-20 swords, the basic 5,the UF2,the kephart and if im right the last chopper pre-order was like 5 years ago in 2019 !...
So imo that's a long time to go without a good chopper being made for sale!...
Frank Cervantes AKA NMFrank87
I’ve noticed that some companies run their CPM 3V at 57-59 HRC. Can anyone explain the benefits of running a scandi ground knife in CPM 3v with the lower 57-59 HRC rather than 60-61 HRC?
Thank you for your time!
Marketing to the… uninformed.Good lord that's not optimal.
A scandi is typically between 11 and 13° DPS. Fine edge stability is critical here.
Also, due to its high abrasion resistance, even at that lower hardness, it's going to be a bear to sharpen with that much bevel in contact.
It is not an optimal alloy for a scandi. But at low hardness? And probably using the secondary hardening hump? That sounds like a real mess to me. I would never do that. What purpose does it serve?
There are plenty of people who simply go for whatever super steel is currently in vogue, without any consideration to either usage, or heat treat.
Plenty of knife manufacturers jumped on the 3V train.
Same goes for Magnacut, when word spread about the new super steel, and as you’ve already mentioned, companies have somehow managed to produce crap examples of Magnacut, despite Larrin publishing the heat treat he came up with in development.
I have no idea. It’s a little confusing, which is why I decided to make a post asking about it. I called their customer support and also asked about what their Magnacut is being heat treated to and the lady I spoke to said that the Magnacut is also being heat treated to 57-59 hrc.Good lord that's not optimal.
Increasing toughness usually comes at the expense of durability
Hey Nathan can you explain the difference?What do you mean by this? Toughness being the ability to break a knife and durability, the strength of the edge?
