Can anyone verify Gastons claims? and can anyone share their opinion on the SP-52?
EDIT: the SP-52 doesn't seem to be available in the EU/discontinued . I think my preference would go to the BK9 as far as my research went.
You can order it here from Ontario's own store. (Cheaper than the Bk-9 at around $75)
http://ontario-knife-store.com/spec-plus-gen-ii-sp52-knife/
It's amazing to think it does not weight any more than 18 ounces, or about the same as a Trailmaster or Bk-9.
I forgot to mention that my Bk-9 had the edge veering off to one side near the handle,
not at all centered to the spine, and others have confirmed this on theirs as well. That is pretty egregious...: I don't think I have seen this on any other knife...
Performance wise I cannot find my old pictures with the Jereboam matching the Bk-9 blow for blow, but you can see the Jereboam here versus a Randall Model 12, and keep in mind the Model 12 is likely
way behind what an SP-52 is capable of at the same 18 ounces weight:
I have owned the Bk-9 for a long while, but never the SP-52: What I say about the SP-52 is based on the design and reviews I have read or seen, and my experience with the handle of the Ontario SP-8 and the handle of the BK-9: Believe me, that is
plenty enough...: You might need to cut off the hook shape at the end of the SP-52 handle, but at least that is easy to do with an exacto blade...: Try doing the same thing on the BK-9, and that is a huge ordeal in comparison...
Some claim the SP-52 sheath is bad, but I have a similar sheath for another knife, and I don't think it is in any way bad: The liner is 1 mm thick rolled plastic that will not crack at all, unlike the thinner plastic of the TOPS sheath liner, and it has true snaps, not Velcro snaps. This sheath does not look as overbuilt as a Spec Ops sheath, but if it is similar to my generic 10" blade sheath (which looks to be the same), it is quite good in design and durability: Unlike Cold Steel's secure-ex, the liner's soft plastic will not dull the edge, and that is a very big issue: Soft non glass-loaded plastic is exactly what you want in a sheath liner, and this sheath has it: Even Kydex is way too hard.
In the 18 ounces range for chopping performance, there is no point in bringing up any of my favourite knives, which the SP-52 is not (just not my thing, style wise): None of my favourite knives would have a chance chopping against it, and neither would a similar size and especially similar weight Kukri: In the words of one reviewer, it is the best chopping knife they ever tested, and the second place knife was not even close... I don't think even a heavier Busse would be anywhere in the ballpark either, but shh!
As another example, the Trailmaster is known to be similar in performance to the BK-9 (maybe a little behind), and that in itself is not that great a thing...:
I don't own the SP-52 because I require fine points on my knives, and I like thin edges that are slicy despite being on a big knife. The SP-52 may not quite fit those point/edge finesse requirements, but for a BK-9 the requirements are usually those of a low-price chopper, and at that game the SP-52 is simply way better and cheaper. To be fair, the BK-9 does offer a small amount of the same versatility I look for in my own overpriced knives...
I know the SP-52 would beat
all my favourite knives in chopping, while being about 10-20 times cheaper, but keep in mind BK fans are not so objective...: A chop off between a BK-9 and an SP-52 would not be a pretty sight... If you have a lot of chopping work in mind, the BK-9 will do it, but it will be a very discouraging prospect: I found the Chris Jereboam pictured above (Cerakoated in ugly green in the picture) far less tiresome to use over the long term, in particular because of the vibration issue in the BK-9 handle.
Gaston
P.S. And yes I did own a BK-9, but that is the only pic I have left of it:
