- Jun 5, 2012
Two other things that have really had a huge effect on my final fit and finish are grit progression and sanding technique. Getting a perfect blend between handle and guard can be quite difficult. You need to not only have the right grits, but the right strip widths if you are hand strip sanding to blend inside curves. You need to know when to use a heavy backed, and when to use flex backed. Also, the right entry and exit angle on the strip, and sometimes have to move the strip to-and-fro during sanding a single area. Getting materials of different density to finish out together as a whole is an art on the level of a master chef plating an entire meal right at the perfect time for each dish.
I find the more discipline I use in my grit progression, the less work overall needs to occur before I get a reasonable quality finish.
