David Martin
Moderator
- Apr 7, 2008
Josh, Thats a excellant one written by Chad Ward . Thanks for the reference . DM
How in the world can you carry a knife for 2 months without useing it?
My thought exactly.
"Cryo" probably means it was an untreated blade chilled in an ice cube tray.
Knarfeng-
I have had carbon steel knives in the same cas with the stainless ones. Carbon steel remained sharp. This seems to negate corrosion-although the carbon knives were oiled, stainless was not.
I just thought I'd point out that if it is in fact bead blasted, not coated, it would actually rust MORE than if it were satin- or even better mirror-finished. The bead blasting causes tiny dents/pits (thus the matte gray color) in the surface, which hold onto liquids and corrosive byproducts, making the end product less rust resistant than one would expect for the given steel.The web site says "bead blasted", but I'm not sure. The point is, it corroded despite these two things.
Knarfeng
I understand what you are saying. Because the stainless was not oiled, that corrosion at the thin edge may have taken place. Interesting. I may sharpen one up and oil it to see.
Thanks.
