- Apr 23, 2009
Thanks Dirk, I appreciate the thorough response mate. Will touch base with the Kizer rep here in Australia.
Edit: on its way back from Kizer, they had to drill out the pivot and replace it in the end.
OK, I disassembled my Escort to see if I could duplicate the spinning pivot issue.
First, the pivot is not a "D" pivot. When you take the pivot screw off, you see what looks like a "D" pivot, but it doesn't run the entire length of the pivot. It is only a notch that extends only about 1/8".
I was able to duplicate the spinning pivot. I removed the pivot screw and then reinstalled. I tightened as far as could and then the entire pivot assembly would spin and the blade developed lateral play. I have seen this happen with other folders and what seems to happen is the thread locking compound loosens just enough to let the pivot screw back out just a bit. Because the compound has filled all of the threads the entire length of the pivot it prevents the pivot screw from easily being tightened. The compound needs to be cleaned out or loosened to permit the pivot screw to be tightened correctly. As counter intuitive as this sounds, I have found this is a bigger issue with pivots that have tighter tolerances.
I would return it to Kizer for repair.
