- Sep 19, 2001
I like frn. It is strong, light, and tough. It provides all the strength a handle needs for a 'broken' (folding) knife with a fine tip and thin edge grind that is meant for cutting, not prying. It is easily molded to ergonomic grips and suitable texturing for comfort & security. It doesn't get searing hot or freezing cold to the touch (my experiences ranged from 14 to 102F while working) My first one-hander was an integral clip delica (which was a bad idea, frn doesn't work for the clips) and my hardest used was a med. CS voyager. My biggest gripe is that it usually means pin construction, and I'd at least like a pivot screw so I can remove the blades for additional cleaning.
Anyone else like frn for a using knife? True, it's no good for pocket jewelry, but it's hard to care about any scratches it receives. An emery board is about all you need to work on it if you want to modify it.
