The Ganzo G8012 Fixed Blade Review
Here is a short review of the knife:
First impressions:
The knife came in 2.5 weeks directly from China.
It arrived in a pretty simple Ganzo branded cardboard box.
The G8012 was pretty sharp out of the box (shaved hair) and had no quality issues.
The tests:
Out of the box it cut paper with no drag and shaved arm hair.
Sits tight in the sheath - no rattle at all and couldn't be shaken out (unless using extreme and improbable force), even without the Velcro strap. With that strap it is impossible.
The cord cutter (which is often confused for a seat belt cutter) works well and allows to cut cord one-handed and without taking the knife out of the sheath.
The included ferro rod gives out good sparks and I reckon will be enough to make a fire in the outdoors.
The knife itself chops and carves wood pretty well, the tip is strong enough to take abuse and passes the tip test with flying colors.
The only thing I didn't test was the very coarse diamond sharpener on the back of the sheath cause there was no need to and I didn't want to use it on a knife that is still sharp.
The Good:
- The execution. The knife is genuinely well made. The handle and the sheath are rubberized (for your pleasure) and the fit is excellent. No rattle or unnecessary movement from any part.
- The ergos. The knife fills the hand great and is very comfortable and pleasant to hold and use.
- The attention to details. Starting from the uncoated area on the top of the blade to use the ferro rod, to the checkering on the back of the "stryker" at the tang, no corner cutting on this one.
- Although the blade shape could remind some of Moletta designs - the overall design is original and couldn't be called a direct clone of any other knife (if you do know of a knife that is 100% similar to this one - please write in the comments).
- The steel performed well and stayed reasonably sharp after the tests.
The Great:
- The added features. With this knife you get a cord cutter, a ferro rod, a striker/hammer and even a coarse sharpener built in, so it could cover most of your survival needs. Great features for the price.
- This knife really gives you enough confidence to actually use and to rely on it for camping, hiking and even survival situations. My experience tells me it won't fall apart or fail during those.
- The price. The fact that you get a knife with original design, this well made and has all those features for this amount of money is not less than amazing.
The Neutral:
- The knife isn't full tang. Could be disassembled and cleaned on the inside using a torx on the striker.
View picture below.
With that, it holds very well and they did apply a white thread locker on the screw to prevent unwanted opening. Like I already mentioned - no corner cutting on this one.
The Bad:
- The GITD inserts serve no real purpose as they aren't very bright and don't accumulate light well. Could easily lived without those.
- The sheath is much longer than the knife itself cause they used separate blades for the cord cutter and put an extra mounting opening at the end of it.
- The Velcro strap does make the knife impossible to shake out, but feels too thin and flimsy (not the best stitching job either). I would really prefer it to be thicker and to have an extra button. Luckily it could be modded and could be folded back (the knife will probably stay in the sheath even without using it).
The Ugly:
- Can't really find anything ugly about this knife, especially for the price.
Summary:
- The quality + fit, finish + added features (cord cutter, ferro rod, striker/hammer and a coarse sharpener) + the ergos + the fact it has original design + the performance + the confidence to use (built well and smart) + the attention to details + the price - the drawbacks make this one of the best budget survival style knives on the market as of today IMO.
It pleasantly surprised me and I am very glad I got it.
*It seems the newer versions of this knife could arrive without the firesteel, because of the post safety regulations (like a firesteel could just catch fire), so please make that point clear if you order the knife.
Video overview and some use:
So, it seems Ganzo have made a breakthrough and made a knife (fixed blade this time) that features in house design and very decent quality for the price.
I hope this knife will be popular and they will make a decent folder that will have an original design to it as well, maybe even a collaboration with one of the known designers out there.
What do you think? Could it be possible?
So it's an uglier version of a Gerber StrongArm.
Impressive.
I don't think they look much alike. I do agree that the Ganzo is uglier though.
Impressive.
I think the Gerber Prodigy is a much better comparison.
In that comparison I'd choose the Ganzo, because of the better sheath, added features and the lower price point (and because Gerber, nuff said).
The gerber is a far better knife in almost every way. It at least has a pointy end. Plus, Gerber isn't a crap clone company like ganzo. Nuff said.
Did you handle the Ganzo knife to form an opinion?
Most of the Gerber products I got to handle were pretty crappy, can't say the same about Ganzo and you also can't say it for the obvious reasons.
At least if you don't want to contradict your own words.
I would never even think about handling a knife that has no point unless I was specifically looking for a chisel type design, which I never have. I've had two prodigies and handled the strong arm. Nice knives for the price. And they both have points. Anyway, I'm not going back and forth with you on this. Everyone can see what it is you are here to do: promote cheap clone companies and their products. Good luck with that.
Can you please remove the video to your clone promotion youtube page. The forum is against clones and your promoting them on your blog and YouTube. Please and thank you.
That blade shape sure looks familiar. Kind of reminiscent of another knife they cloned, the Lionsteel SR1.
This thing just screams "Harbor Freight Special". It may be a decent tool, but there's no way in hell I would rely on it for hard use.
Fox Pro Hunter has a similar blade shape. So do many of the best machetes out there.
Not any knife needs a prolonged tip, and this is just fine for most works it is intended for.
So I wouldn't write it off just because of that (although I understand where this is coming from with your opinion on Ganzo knives in general).
See nothing wrong about reviewing budget knives in here as well, as long as it isn't a fake or a 1:1 clone of another knife. Thanks.
Yeah I understand that. I just don't see the correlation between the Ganzo and a machete. Two completely different animals.
I merely brought the machete as an example of a (very) usable knife type that has a similar blade shape.
Ahh ok.
That blunt tip still doesn't seem to make much sense on such a small blade. Definitely not my first issue with this knife, but it's a big one considering it's overall usefulness has diminished because of that bolo style tip.
What USEFUL task you wouldn't be able to perform with a knife that has this kind of tip?
