This article is from the research of another member: "Delrin is an acetal thermoplastic resin (PolyOxy-Methylene or POM) which has a semi-crystalline structure, is machinable, and possesses excellent strength and dimensional stability, high lubricity (low friction characteristics), and good wear resistance.
Dupont’s advent of Delrin came about from their post-WWII search for wider applications of their popular nylon. When Department director Frank McGrew and their chemists in the Polychemical department searching for a plastic replacement for metals first came across the formaldehyde derivative which we now know as “Delrin”, they named it “synthetic stone”. This was circa 1952. It took another four years of development to refine the process for production and in 1956 they were granted the patent for Delrin. Another four years and twenty million dollars was invested in a facility to manufacture Delrin, and in 1960 the plant in West Virginia opened and began large scale production with a twenty million pound annual capacity.
After a total fifty million dollar investment, Dupont cited patent disputes and competition for shallow profits on the material. Bad for Dupont, but a boon for the knife industry as Delrin quickly became a premier handle material for many companies, Schrade and Camillus included. Nearly fifty years later, Delrin is still an important material in the cutlery industry.
Along with the properties of Delrin already mentioned, another very important one exists which makes this plastic such a winner for knife handles. It can not only be colored as a base material, but it can be dyed after molding to add accent colors. This is what gives “Staglon” it’s stag appearance, and “Genuine sawcut Delrin” it’s sawn bone appearance.
After the Delrin handles are molded, sprues and gates (sometimes called runners) trimmed, they had to be dyed. Two heated dye tanks are used, one brown for OT covers, and an additional black for the UH covers. The tanks were heated to 180 degrees, far below the melt temperature of Delrin. but hot enough for the dye to penetrate the surface and set. I am not familiar enough with this particular dye to tell you what the color base material and mordant are, but most dyes (as with most paints) have mineral base ingredients. A mordant is a chemical (usually acid or alkali) which acts as a penetrating agent and carrier solution. Like the vinegar used with Easter egg dyes. In this case, it could well have another type of mordant.
The covers were dumped into the first dye vat and an operator stirred the parts every few minutes to prevent the parts from streaking from dry spots, and weakened dye, or contact with the vat. They also occasionally lifted some parts with the stir paddle to check the color. If the dye was fresh, time in the dye tank was about 25 minutes. When the dye was weakened from use, dying times were extended by the operator to compensate, until they judged the dye needed replacement.
This whole operation was dependent upon the judgement of the operator. When the parts reached the desired color, they were removed from the dye vat with a shovel and are placed in a basket in the rinse tank. After rinsing clean, the basket was lifted and drained, and the parts spread on a drying table. Ours in the machine shop are perforated stainless with reversible air flow for updraft heated air, or downdraft cool air, depending on the part.
At this point, the covers would be a uniform dark brown color. For the UH covers, they went from the brown dye (approx. 15 min, or until the proper reddish brown color is achieved) then to the rinse, then to the black dye tank for another 10 minutes or so, depending on dye strength. They were again rinsed, and went to the drying tables.
The fact that Delrin takes and holds dyes so well made the material a good substitute for celluloid handles of ad specialty knives also. A heated die was pressed onto the handle over a dye tape, scoring the handle and filling the impression with dye. In 1975, the resident Schrade artist, a very talented man by the name of Frank Giogianni, bored with the commercial art he created for packaging, logos, and commercial ad knives, presented Henry Baer for his consideration a cream Delrin handled scrimshaw knife of his own design. Baer enthusiastically approved and the commercial art became creative decorative art and the popular Scrimshaw series was born."
