- Feb 2, 2005
I have never played with a Delica before. As I have smalish hands, would I be able to get a full 4 finger grip with the Delica? My Native is pretty much perfect.
Even with "not-so-smallish" hands you should be able to get a 4-finger grip on the D4 handle. The elongated shape of the butt end of the handle allows for more gripping space. The D4 handle is narrower top-to-bottom than the Native handle so it won't have the same feel in your hand that your Native has, but you should be able to get a secure grip on the Delica.
MVF...
To me, the Caly is a different knife. The handle materials and construction techniques are different, the blade grind and profile is different, even the locks are different even though both are backlocks.
The Caly 3 has full steel liners and pinned G10 scales. It is a very rigid knife with first-class machining and fitting of parts. The Delica has nested liners with FRN scales that are screwed on rather than pinned together. The pin vs screw attachment is no concern either way to me, it's just a difference. FRN is easier to work and less expensive to use than G10, but just as tough (or maybe even tougher, as far as impacts are concerned). But Spyderco's G10 "feels and looks" like higher quality to a lot of people, me included.
The lock spring on the Delica seems to be slightly stiffer and the lock bar drops a little deeper on my Delicas than on my Calys. It may not really translate into a stronger lock, but then again, it might.
The Delica blade is a flat saber-ground blade of VG10. It's extremely strong in that material and profile. It sacrifices some slicing ability for added strength from the saber ground part. The Caly 3 blade is a wide, flat-ground VG10 blade that starts out as thick or a little thicker than the Delica, but immediately tapers to the edge of the blade. That make for a blade that is a phenomenal slicer because it's thin at the edge and has smooth sides compared to the saber grind on the Delica. The Caly 3 blade probably won't take as much lateral stress (prying) as the Delica, but a 3" folding knife's not a prybar, anyway.
IMAO, all of that adds up to the Caly 3 and Delica series just being different knives.
Sorry to be long-winded, but you didn't say whether you'd ever seen or held the knives before, so I thought I'd try to give a brief
