ashwinearl
- Nov 9, 2006
I have 60W MOPA Haotian in two pieces. With the two piece unit, they are connected by a permanent fiberoptic cable. It is not a plugin cable. It makes moving, setup more challenging as you also don't want to bend it very much as it is fiberoptic cable. A single unit is naturally heavier by itself, vs separating the weight into two parts.I'm getting to the point where I need more etching stencils and I'm considering a fiber laser instead. I see some machines appear to be one piece and others appear to be two piece. Is there an advantage/disadvantage to either? Assuming both are 60 Watt.
For those take their laser on the road to craftshows, doing stuff live onsite, a one piece makes more sense.
I think an advantage of the two pieces is range of how high you an set the lens. This probably isn't a big deal for knives and the typical lens you'd be working with like a 100 or 200. But if you stick a rotary on there for tumblers that make the work taller, then a big lens, you might be running out of vertical space on the tower.
