Tommegow said:
"For O1 you would want any of the medium speed oils that are general purpose."
Mr Cashen I would like to know what a medium speed oil is? I can barely afford the O-1 steel I am starting to grind. What in your opinion is the best cheap oil for the absolute newb
(with very little money to invest at this point, but with several blades to HT?)I can not afford to send them off either
Respectfully
Tom
Tom -- I am new too, and ended up using olive oil on my O1. Between my one-brick forge (which is cheap, but no where near optimal, and which I am still struggling to use correctly) and the sub-optimal quench, I have been disappointed with the results on my O1. It is discouraging to pay for good O1, invest the time (and it takes a lot of time for a newb) in grinding, end up with a nice blade, spend the time on a fit and finish for the handle, but end up with a sub-par knife. While I have a couple of nice looking knives under my belt now, knowing the heat treat is not great reduces the "pride factor" considerably, at least for me.
It is probably more a problem of reaching and soaking at critical temp in my forge than the olive oil, but I've decided to get proper quench oil, so at least that area will be optimal. Other than that, I'll have to try to get better with the forge until I can aford a heat-treat oven (note that a good forge and pyrometer are just as effective in skilled hands -- my one brick forge doesn't qualify as a good forge, and my hands don't qualify as skilled
In short, try not to skimp on the quality of heat treat -- otherwise, the money spend on the O1 is sorta wasted. If you really can't afford proper quench oil, veggie oil will work. Correct me if I'm wrong, Kevin, but I'm sure my problem (and the biggest problem with other newbs) is getting to critical temp and holding, rather than the quench speed, and if you don't hit that right, the quality of quenching oil probably won't make much of a difference.
One other note -- be patient with your first few knives. If I had slowed down and re-done the heat treat until I was satisified, rather than rushing on to the handles and finish, I'd have better knives under my belt. As long as you don't drastically overheat the blade, you can heat, quench and temper as many times as you need to get it right. Only problem is, as a newb with no RC tester, how do you know when it's right
