The New CRKT Crawford-Kasper KFF!
Hi All!
I was thrilled when I first heard that Columbia River Knife and Tool Co. was going to make a production version of the fantastic Crawford-Kasper Fighting Folder(KFF). I had always wanted to own a KFF, but just couldn't bring myself to spend the cash for Pat Crawford's custom version. The CRKT KFF seemed like just the solution I'd been waiting for. Then I learned that CRKT had chosen to use AUS-6 for their KFF, and I- just like many of you who posted on the Forums- was disappointed. I was concerned that the AUS-6 was not a quality Stainless Steel capable of withstanding the rigors of training, much less combat. It made me question the quality of the whole knife.
I decided, after reading misque's and 2Sharp's terrific initial reviews of the CRKT KFF, to try and find out if it could perform up to the level I, and other bladeplayers, need in a tactical folder. They inspired me to E-mail CRKT and ask if they would send me some to put through my usual battery of test and then post a review of my findings for you all.
Rod Bremer of CRKT got back to me immediately. He readily agreed, and quickly sent me some KFFs from the first production run as well as info on changes that will be happening in future production runs of the KFF(which I will detail below). Rod's been absolutely terrific to deal with from Minute One.
First, a picture of the CRKT KFF in its various forms:
First Impressions:
The pics I had seen in no way prepared me for how substantial the CRKT KFF is- this is one honkin' sturdy folder! The handle is 5 1/4" long, and 1/2" thick looking down at its spine. It is a 1 1/4" wide from the spine side to the edge side at the front end of the handle and at the pommel. And, the KFF weighs 7.5 oz.! But, in no way does it feel heavy or awkward. The KFF feels tremendous.
I was amazed by the ergonomics of the handle and by how instantly comfortable and familiar it felt. When open, the KFF is 9 1/2" in OAL, and with its balance point right at the forefinger groove, actually feels much more like one of my favorite finger-groove handled fixed blade fighters than a folder.
Fit and Finish- The grind lines of the blade are perfectly symetrical and it is polished to a nice satin finish. The blade rides perfectly centered between the scales in the closed position. The blade opens very smoothly with either the thumb stud- which is ambidextrous- or with a snap of the wrist. In the open position, the blade is rock steady at the pivot.
The liner lock engages securely, and the secondary LAWKS safety mechanism is intuitive to operate and effective at preventing the liner lock from disengaging.
The handle scales, of Zytel, are textured and the edges nicely rounded. The stainless steel liners show slight cutting marks and the steel spacer isn't perfectly flush to the liners at one spot along its length, but, other than that, the overall fit and finish of the knife are excellent considering its price- certainly better than I ever expected.
The KFF arrived hair-popping sharp.
The clip is on the right side, positioned for tip down carry. It is not reversable. It is fastened at the extreme forward edge of the handle, so that the knife rides virtually completely concealed when clipped in my pocket.
Feel and Maneuverability:
As I stated above, the KFF felt amazingly comfortable and familiar in my hand from Minute One. This sense of comfort and security only grew stronger as I used the KFF against a variety of targets. The knife was totally secure in my hand during full speed, full power slashing, witiking(snapcutting), thrusting and checking against both my training dummy and the De Cuerda(hanging rattan target). I developed no hotspots or blisters, no hand irritation of any kind, even after over two hours of continuous hard training on each of two consecutive days.
The KFF moves effortlessly in my hand, transitioning easily through all grips in realtime while attacking targets. It is wicked fast and accurate against hanging targets of all kinds, and a real joy to use.
Accuracy:
I can hit within 1/4" of Sharpee dots drawn on a sheet of cardboard that I hung and set to swinging, at will. This is extremely accurate for a folder of this size.
Impact Resistance:
The Dreaded De Cuerda- This was a crucial test for the KFF and for CRKTs choice of AUS-6 steel for this knife, IMO. By harsh experience, I've found that folders are often not sturdy enough to withstand repetative impact against the De Cuerda, and suffer failure at the pivot joint or lock even if the blade survives. I was shocked, therefore, when the KFF performed absolutely brilliantly against the De Cuerda.
I executed full power witiks, backcuts, slashes, and parries with the edge, spine, and flat of the blade in realtime against the rapidly swinging rattan and the KFF took it all in stride. The AUS-6 blade cut nicely into the rattan(many blades just bounce off), and it suffered absolutely no damage- no chips, no rolled edges, nothing. The blade actually showed no signs of having been used at all.
The liner lock held firmly through the entire test. The LAWKS mechanism did have a tendency to slip backwards slightly from its fully engaged position under the rigors of impact, but it never disengaged. I normally do not use a saber grip. If I had, my thumb would have prevented this movement of the LAWKS lever.
The blade developed the slightest lateral play at the pivot after two days of testing, but approximately 1/16th of a turn with the torx driver returned it factory specs. I have to tell you that most of the folders I've used against the De Cuerda become quite loose at the pivot very quickly. So this is an awesome result, and one which really surprised me.
The Training Dummy- The KFF cut cleanly through the dummy's skin and deep into the foam underneath- excellent! The blade geometry of this knife is outstanding. Thrusts were absolutely fantastic as well- all the way down to the wooden core, with no flattening or bending of the blade's tip. Likewise, the edge once again suffered no damage against the training dummy. It did lose its shaving sharpness and had to be resharpened with my DMT diamond hone, but that is not unusual.
Further Cutting Tests:
Single Hanging Sheet of Paper- the CRKT KFF cut cleanly and straight through the paper at any angle.
Hanging Sheet of 1/4" Cardboard- Here again, the KFF slashed straight and clean consistently 4"-5" in from the edge of the cardboard.
The Hanging Roll of Exam Room Paper- The KFF cut extremely well into the roll of paper in realtime, often all the way down through the paper and sometimes through the cardboard roll inside. My BM 710 will not do this. With thrusts, the tip penetrated all the way down to the rattan pole beneath. This is a tremendous result for a blade of only 3 7/8" in length.
Leg of Lamb Cutting- I executed several slashes and thrusts at various angles through a large leg of lamb with the KFF and it cut through the dense fascia and muscle beneath effortlessly- no resistence at all. Long, clean cuts measuring a good 4"-5". It even consistently cut a good 1/2" or more into the femur bone of the thigh, once again with no damage whatsoever to the edge.
Thrusting was also effortless- all the way to the hilt and beyond. I purposefully thrusted against the femur bone several times and the tip bit in well and sustained no damage. In fact, the whole blade looked completely unused after all this cutting, and remained razor sharp.
So, there you have it .
IMO, the folks at CRKT have created one hell of a fine tactical folder in the KFF, using Bob Kasper and Pat Crawford's outstanding design. I own production and custom folders, some costing over six times as much, that cannot do what the KFF did. That's amazing. I have to tell you guys that I never expected the CRKT KFF to perform anywhere near this well given my prior experience with other inexpensive folders. And, for me at least, the question of whether or not AUS-6 was a good choice in steel for this knife has been answered. It works beautifully.
I have so much confidence in the CRKT KFF, in fact, that I intend to buy two for myself to replace my Mission MPF and BM 710 as my daily carry blades.
Negatives? My only suggestions to Rod for future production runs were:
1.To deepen the forward detent of the LAWKS, so that it is less likely to partially disengage during training against dense targets.
2. The clip on the knife is very smooth, providing little purchase for the index finger. Likewise, the handle scales are rather smooth as well, providing little grip for the thumb. It is easy therefore for the fingers to slide off the knife when one is trying to draw it rapidly from its clipped position in the pocket or waistband.
I taped some bathtub traction tape along the clip and trimmed it to shape with a razor, thus increasing the grip for the side of my index finger. I next roughened up the handle scale on the opposite side of the handle from the clip in the area where my thumb touches as I grab the knife to draw it. This gives the pad of my thumb something to grip. With these two minor modifications, I can now draw the KFF from its clipped position in my pocket or waistband very rapidly and securely every time, snap it open as I draw, and bring it to target in one fluid motion. Its perfect. Therefore, increasing the grippiness of the clip and the scales in future iterations of the KFF would be useful.
3. Make the clip ambidextrous.
I realize that these suggestions are minor and almost ridiculous to suggest in a knife that is so inexpensive, but I thought that CRKT- and you all- ought to know about them since they improve the knife's tactical performance. Rod assures me that they will consider these changes for future production runs. He also informed me that at due to feedback from Bob Kasper, in approximately 45 days, the next generation of KFFs will have:
1. The serrated section of liner- at the area of the choil behind the lock- will be lowered 1 mm to sit flush with the handle/frame.
2. The barrel of the LAWKS liner lock safety will be shortened so that it rides below the surface of the handle/frame.
The bottom line? I'm blown away by The CRKT KFF's feel and performance. The fact that it costs so little is just icing on the cake- delicious icing, to be sure, but just icing nonetheless. After the way it performed(and BTW, each of the four KFFs that CRKT sent me demonstrated the same high level of fit and finish and performed exactly the same), I would buy this knife, as is, even if it cost quadruple what our very own One Stop Knife Shop is selling it for. Now, would I someday like to see CRKT produce a slightly more upscale version with fine micarta scales and a finer overall fit and finish? Absolutely. Is it necessary, Hell no!
Bravo, CRKT. Bravo!
Mario
Gaucho
Tuvo muy mala suerte...se callo en mi cuchillo.
[This message has been edited by Gaucho (edited 05-11-2000).]
Nice review! I agree with your recommendation to make the clip ambidextrous. I also believe the LAWKS should use a spring to automatically engage it. Something like a lighter version of the spring used on the Benchmade 710 lock. Good job.
Cheers,
Damon
Thanks Damon
I'm glad to hear that someone else who's used the knife agrees with my findings.
Mario
Gaucho
Mario,
Thanks for an excellent review. I was pleased to read that it passed your rigorous tests.
Originally posted by Gaucho:
Hi All!
I decided, therefore, to try and find out what the real story was on the new CRKT KFF. I E-mailed CRKT and asked if they would send me some to put through my usual battery of test and then post a review of my findings for you all.
First Impressions:
The clip is on the right side, positioned for tip up carry. It is not reversable. It is fastened at the extreme forward edge of the handle, so that the knife rides virtually completely concealed when clipped in my pocket.
Accuracy:
Impact Resistance:
Bravo, CRKT. Bravo!
Mario
Thanks for the outstanding review. I have wanted a KFF for quite awhile, but like you wasn't sure about spending the dough. I recently noticed the CRKT KFF advertised and thanks to your review I'm going to try it out.
Out Here, Dens51
CeeJay and dens51,
You guys are both welcome
dens, I'm flattered that you liked my review so much, but did you really need to quote the whole thing?
Maybe you could edit out that section of your post so that folks don't have to scroll down through it all again. Thanks. And let us know how the KFF works out for you.
Mario
Gaucho
Gaucho, I'd like to thank you also for your review. I am going to buy a small KFF, plain edge to replace my every day carry (Spydie Walker Lt/Wt) I'll never put the knife through the tests that you have, but it's sure good to know that it will stand up. I wasn't at all surprised by the great price from CRKT, they always seem to give you a lot of knife for the money. I've handled Crawford's customs enough to be in love with the feel, if this knife comes even close this will be a hard knife to beat.
I may just have to order a large one also.
"Will work 4 Knives!"
Homepage: http://albums.photopoint.com/j/AlbumList?u=254126
Leg of Lamb Cutting Test?!
Now, that's going the extra mile! Thanks for the outstanding review, Gaucho!
I'm amazed every time I pick this folder up at the outrageously great value that the knife offers!
If you get the oppurtunity, pick up a CRK&T Point Guard. Another winner from a company that seems bound and determined to give the consumer more knife than what they paid for.
I REALLY like that!
Again, great review, Gaucho!
And great job CRK&T!
The individualist without strategy who takes opponents lightly will inevitably become the captive of others.
Sun Tzu
SB
Yet another spendid review, Gaucho.
Chalk me up as another CRKT KFF fan.
I also agree that the clip needs to be reversible. All that's required, I think, it to have three holes drilled for the screws? I would've bought another one on the spot if the folder had this feature.
Because of the LAWKS, it does almost beckon the folder to be used primarily with the saber grip, though not necessarily.
I can't believe how such a great design can be available for such a cheap price (I haggled mine down to $40 at a gun show), despite the concessions made.
Nice work! I have in mind both knife and review
Maybe I'm not the greatest KFF design fan but I'm great CRKT fan and have no doubts - they made their job perfectly.
You Gaucho also. Thanks for review
Sergiusz Mitin
gunwriter
Lodz, Poland
This is truly one H*** of a knife for the money. And, just a GREAT knife-period. It would sell at double or triple the price. (Don't get any ideas, CRKT!)
I wonder if the clip can be replaced with one from the EDI Genesis? That would be a good modification.
Cheers,
Damon
Thanks, Gaucho! That's one great review. I had never seriously considered buying a CRKT before. But I just noticed that I happen to have an empty space shaped just like one of those. What a coincidence...
Dave
Attention: Some assembly may be required. Batteries not included.
Gaucho,
Great review. I especially liked the use testing. I'm glad that you like the Kasper design as much the rest of us.
I was able to handle the CRKT KFF at a local store. It is very well finished. I didn't care for the liner lock sticking out past the scales. I did like the LAWKS though. I considered getting a modified KFF from Kevin Gentile which includes recessing the liner lock, but now I think I'll wait for the next production run.
I was impressed with the smooth action of the knife. The dimensions of the knife is very similar to my customs, except that the overall handle thickness is less. I agree with Damon that it would be great if the LAWKS was self activating.
When I train with my Custom KFFs, I do a drill which involves drawing, opening, followed by a thrust. Manually activating the LAWKS would require that I recondition my muscle memory. Like Gaucho, I don't use the saber grip much. The LAWKS would require me to go to a saber grip then back to my natural grip before thrusting.
Of course, I could skip the LAWKS for speed drills and just rely on the liner lock. I have mentioned before that my custom KFFs have an additional 1/2" of unground section of blade near the pivot. This is my version of a knife safety. If the lock should disengage, then the unground section would contact my forefinger saving it from a cut.
As far as the smoothness of the handle is concerned, I have had the micarta scales of my custom KFFs gun checkered by CheckerMarx. I choose to carry my KFFs in an Inside the Pocket knife sheath so I removed the clip. The gun checkering really improves the grip and makes for secure draws and openings.
I asked Julie Marx of CheckerMarx if they could checker Zytel. She said that they had never attempted it and would like a sample to test first.
When you say that the barrel of the LAWKS release will be shortened, do you mean that the length of the LAWKS release will be reduced or that the diameter of the barrel will be reduced?
I have a Crawford designed KFF trainer which I use for impact training against my bag and training dummy, so I am in total agreement with your comments on the handling, comfort and security of the KFF.
I'll eventually buy the CRKT version as a low cost backup to my customs.
Hey Damon, have you picked up the CRKT version yet? Kevin is asking $85 delivered for his modified version.
Axel
Thanks all for your kind words. I'm glad that you've found the review useful in your decision as to whether or not to try the CRKT KFF.
Axel, thanks in particular for your imput as an experienced bladeplayer and custom KFF user. I'm glad to hear that you too came to the same conclusions re: useful modifications to the KFF. I just saw that you posted a new thread on checkering the KFF's handle. I'm going to read it right now.
Mario
Gaucho
Hey Gaucho!
Thanx for doing this most excellent review, i never got my ass off the wagon to do some actual cutting test...
Sounds very good and now i have even more faith in my CRK&T KFF, just can't let my Commander go...
This "De Cuerda" can you please elaborate on how it works? i sounds that i should know what this is, but i just can't get a picture popping up!
Thanx for an excellent review!
Be well!/Jonas aka 2Sharp
"May all your detonations be expected"
The coolest bar in the world: http://www.geocities.com/Pentagon/Camp/8373/index.html
dogboye
Interesting review. It almost sounds like AUS-6 from CRKT can give a lot of these other wonder-steels a good run for their money.
iktomi
Hey All!
I just wanted to update you guys on the CRKT KFF.
I decided to carry one all the time as sort of a longterm testdrive
. I use it for general cutting chores, as well as train with it several times a week against my usual array of targets and training aids.
The CRKT KFF has held up like a champ. It remains rock solid- and I tell you that by now I must have drawn and opened this knife with a wrist snap several hundred times since I got it, not to mention the continual abuse that its taken against the De Cuerda and my other targets. And its still razor sharp.
This folder continues to amaze me.
Mario
Gaucho
Pregunta: "Hay rumor que sos cuchillero. ?Es verdad?"
Repuesta: "Prefiero pensar que el acero de los gauchos core en mi sangre."
I recently purchased 2 of the large plain edge CRKT Crawford Kaspers.
My buddy and I are both well pleased with the knives except that the blades aren't centered in the handles when folded and you can hear that sickening "snick" of the blade rubbing the liner when you thumb them open.
I wasn't particularly thrilled with the idea of the LAWKS (not to mention I think it sounds stupid), but engaging the device IS intuitive and should calm a few nerves for those who distrust liner locks.
My 7 year old daughter picked up the knife, opened it, put her thumb on the LAWKS, engaged it, flipped the knife over to try and close it. When she couldn't move the liner lock over she looked at the knife studiously for a few moments and said "OH I SEE! That little lever keeps you from being able to close the knife!" Then she disengaged the LAWKS, closed the knife, and handed it back to me stating, "It's pretty big and heavy."
Not a bad system if a 7 year old can make it work.
I had first considered geting a CRKT KFF after seeing so many recommendations for it here on BF. My only reservation was the price (too low, not too high). After handling one at a store yesterday my mind was made up. I ordered one from 1SKS about an hour ago. THEN I stumbled upon this review, and I am even more excited to get it. Great review, keep 'em comin'.
Jason
"I have often laughed at the weaklings who call themselves kind because they have no claws"
- Zarathustra
