Just to present the "contrary" position, the Ayoob C60 is/was designed as a SD knife.
As a "fan" of SD knives (of which I have MANY, which is why I bought the C60 in the 1st place), fully SE blades do NOT function well as such BECAUSE when you attempt to cut thru cloth (which the perp will almost certainly will be wearing) the serrations hang up in the cloth and do not cut cleanly as a PE blade would.
If you use your C60 for NON-SD purposes, fine but, if you are using the C60 for what it was designed for, grab your PE version instead.
Take my word for it but, if you don't believe me, set up a dummy w/a jacket on and see what happens when you attempt a back handed slash cut on it w/the soon to be released fully SE version.
It will hang and stop and the prep will knock your lights out, unless you block the strike and use the C60 as a stabbing weapon instead.
Just saying . . . LOL!
BTW, I have NOTHING against fully SE blades but their usefullness is limited to maybe 10-20% of the tasks that you may face.
Like any tool, use the best one for the task at hand and, if the task requires a fully SE blade, grab one but for daily duty a PE blade will function fine and will event handle the tasks that a fully SE blade will handle better but it will just take a little more time.
If in doubt, carry a PS blade instead. Is there a PS C60 in the plans?
Everything with a grain of salt I suppose.
Real world "usage" is hard to quantify for these situations but here's a "fun" one.
https://forum.spyderco.com/viewtopic.php?t=72657
