Very well said!
I was going to try to post some pics of the one that I was lucky enough to get and was going to do a write up on it but I'll just add my .02 to your thread.
It really is a home run, right out of the park!
I made a vid that I haven't posted yet where I talk about some of what you mentioned, it really is it's own unique knife, it isn't a Zaan, nor is it a Sebenza. I think that CRK should've graced this amazing knife with it's own moniker.
It's a sort of a hybrid of the Zaan and Sebenza, and feels more stout than the Zaan but more refined like the seb.
The blade and handle stock are the same as the Zaan, it uses the same pivot as the Zaan and Ti lock, there's no bushings which the Sebenza is known for, it uses the same lock interface as the Zaan( just a bigger ball ), has no locating hole like the Zaan, and seems to be a hard use knife just like the Tanto umnumzaan that I carried for two years- amazing!
It keeps some similar profiles of the old trusty Sebenza with some obvious changes, it also has some under the surface changes that non knife nuts wouldn't notice, but us knifeaholics will speak of for years to come.
The trademark pivot bushing is of course gone, it uses a stop pin like a sebenza but it's completely redesigned. The pin is press fit into the left scale and there's a flat cut into the pin, into what would be the collar portion of the classic/21 stop pin, the rear stand off has two screws that screw directly into it and are completely different than how the classic/21 had the bolt and collar, the locating hole is gone, the lanyard hole is gone, there's an added choil, there's milling in the rear of the handle to accommodate the lanyards knot ( I've seen two different styles of this in the first thirty knives ), the lock side washer is now locked into place by a tab that sinks into a recess in the blade, it's also larger and notched for the lock bar, the edges are very well rounded like my old Regular Sebenza, the clip is bowed out slightly in the portion that is normally flat, and the bladevseems to fall somewhere between the Classic/21 and the Regular in it's profile; it's also ground with what they're calling their high hollow grind which feels almost flat and cuts like a pocket light saber- way better than my Star Tac side by side and both factory sharp, it's a great change that keeps more steel in the blade and gives a crazy keen edge!
I guess that the 25 will suit it fine as a name but the Umnumbenza or Sebenzaan would just seem more fitting, or, something completely unique, which this amazing knife deserves!
You guys are saying that it's smoother than your Zaan's but mine has a gritty ferruling to the lock when I unlock it that just started today, cleaned it up but it's still there. I can see fine lines on the tang of the blade that are most likely the culprit but it's no big deal; definitely not as smooth in operation as any of my three Zaans or the other four that my buddy Blackend has had. I'm sure that it'll smooth out in time.
