MT_Pokt
- Jul 21, 2014
I have some old 12 gauge I brought back from Dad's. There's no corrosion at all, so I figure they should be fine. Certainly worth trying. OTOH I have a handful of 20 gauge that have, what I consider to be, significant corrosion and I'm not putting them in a gun. I don't think they'd blow up the gun, but they might be difficult to get out, assuming they fired.102 & 410—I don't have a pistol, just rifles and shotguns. A friend gave me 5 boxes of 410 ammo. Check the price and date. I need to go out and see what the shelf life is on the ammo.
I picked up a DE at a gun show, looked at my buddy and said, "Well this is just too big for my little girly hands"Another repost from Buck n Guns. Desert Eagle .50 and Buck 3/4 D Handle.
I see no corrosion on these. I know they were stored in a cool, dry spot so I'll give them a try. Of course the 102 in the photo is older than the ammo.There's no corrosion at all, so I figure they should be fine
From everything I have read, cool and dry are the key. I am still working on a box of 12 gauge from the 1980s with a TG&Y price tagI know they were stored in a cool, dry spot so I'll give them a try.
you'd think that, and I've heard it too and still believe its best method...From everything I have read, cool and dry are the key. I am still working on a box of 12 gauge from the 1980s with a TG&Y price tag
Huh. Maybe I'll reconsider those 20 guagesyou'd think that, and I've heard it too and still believe its best method...
but when my father in law died and we cleaned out his sheds and garage and such...I found ammo galore from the late 60s, 70s and 80s that had sat in super high humidity and heat and I shot all of it and almost all of it all went off. all the center fire and shotgun shells went off. they were corroded and in bad shape visually too. the rimfire had a few failures, maybe 1 out of 100......anyways.....
be careful though, just cause I did it doesn't mean it was a good idear........Huh. Maybe I'll reconsider those 20 guages![]()
One thing about Wyoming is that cool and dry is an easy condition to find. My 410 is a Stevens 311A sxs from about 1951, and I predate both. I guess the combination of old ammo, old shotgun, and old shooter will have to check this out.you'd think that, and I've heard it too and still believe its best method...
Understoodbe careful though, just cause I did it doesn't mean it was a good idear........
maybe I got lucky.....? I've read heat exposure in ammo can cause higher pressures. I wouldn't use an antique or valuable gun.....
I should mention I did clean off the corrosion from the brass shotgun shells . no major work just rubbed off the crust with paper towels and made them smooth again.....made sure the plastic hulls were in good shape still flexible......that kinda stuff.......Understood
My 20 is a Western Auto pump, which is a Mossberg 500. Not super valuable and pretty stout.
That was the reason I decided not to try them. I have a whole box with some corrosion and separated, the "not bad they should be ok" from the "hmm. not too sure about these". I'll take another look at them. The only reason I still have the suspect ones, is I wasn't sure how to safely dispose of them.in the end though decide if the few bucks not wasted by shooting them is worth any of the potential risk. probably not.....but I tend to be cheap, stupid and hate waste........
