The Ultimate Lubricant Thread
Wow! You guys are intense.
I use nothing on SS kitchen knives, EVOO on the carbon blades, even the keepers that will never see any kitchen duty. Some have been put away for a long time and the oil has not gone rancid, or at least I can't smell anything unusual.
I use FP-10 on my carry folders and I have a question. As soon as the Kershaw 13C26 rainbow leeks are released I'm going to get one. Do any of you know if FP-10 can in any way chemically alter the rainbow finish?
Buzz
Hi
I have recently tried Renaissance wax.It is also known as museum wax.I can't say yet how well it works,just tried it a couple of months ago.I will tell you this, the stuff will make your knives shine! It is good for bone, Pearl,Celluloid or wood.I am not sure long term how it will hold up I am watching it close.But love the way it shines.A little expensive,but we are talking about our knives here.Thanks enjoyed reading what everyone had wrote wanted to put my two cents in. jarhead52 :thumbup:
FP-10 won't harm the rainbow coating at all. I don't have any rainbow coated knives, but with alot of the vapor deposition coatings they're porous, so maybe it'll soak in and alter the color a bit, degreasing will fix that.
Hi
Sounds like a mixture of a polymer (like in synthetic carwax) and beeswax, which is archival. Quote from their website:
A consortium of international conservationists directed a scientist from the British Museum to conduct intensive research and find the "perfect wax." When he could not find any that met their exacting standards, he created a new wax in his laboratory. The revolutionary formula he invented is a semi-synthetic micro-crystalline fossil-origin wax entirely free of, damaging acids. It remains chemically neutral and is therefore completely safe, even on vulnerable surfaces.
The British Museum approved manufacture of this wax for its own use and for distribution to the public. That "perfect wax" is now available internationally under the name RENAISSANCE WAX.
RESTORES AND ENHANCES
Revitalize and return your objects to pristine condition. RENAISSANCE WAX buffs easily to a hard, transparent finish that will not discolor; Renews fading colors and "tired finishes;" retains matte finish when unpolished; buffs to a high gloss; reduces shine of new picture varnish.
POLISHES AND PROTECTS
Guard your precious pieces against the damaging effects of humidity, heat, dust, environmental destruction, aging, and ordinary wear. RENAISSANCE WAX provides a barrier against fingerprints and the devastation of water, wine, alcohol and other spills. With its high moisture resistance, it forms a durable, lustrous protective coating. Prevents tarnish, corrosion and "bloom;" remains completely waterproof; retards weathering on exteriors and objects exposed to climatic abrasio
Problem is, I don't see how it will penetrate into the tight joints of a knife.
Has anyone tried Liquid Wrench L4?
I currently use Militec and have used Triflow, I was considering CLP because I completely dislike the militec application and odor.
I was checking the site for L4 and the wear test and coefficient of friction looks better than CLP. http://www.gunk.com/webassets/word_documents/L412_COMPETITION.doc
(the comparison is near the end of the document)
Does anyone has experience using this lube?
Thanks
Hey just a quick question, do you guys know of any retailers that sell Firepower FP-10? I was thinking about trying some out for the knives/firearms I own.
I use Lubriplate FMO-AW oil and the SFL-0 grease. It is food safe and has awesome protective qualities. No smell and it stays on the blade well. I got a kit at www.lubrikit.com
I bought a kit for my automatic handguns and decided to try some on my knives. I took the knife apart and put a dab of the grease under the washers and it is still there after a month of daily use.
Eezox is great stuff. I was using Militec-1 until I find Eezox. It's the best IMO.
I've been using Rem Oil and it seems to work just fine for me. I'm not exactly worried about rust or corrosion, considering most of my knives get only light use.
Also doesn't hurt that I'm obsessive enough over my knives that even cutting through an envelope or small patch of tape is excuse enough to break out the Rem Oil and chamois.
I've just recently began using Ballistol Sportsmans Oil for lubrication,cleaning, and rust prevention. It's non-carcinogenic and biodegradable, but it does smell a little funny. Before food prep, I would still wipe my blades clean and then reapply oil when finished. I've read the MSDS and I feel comfortable that it is safe to use. Here's the MSDS in PDF - View attachment ballistol.PDF
I have own slip joint style knives with bone handles. I use mineral oil on the handles to preserve the colour throughout the bone. and 3in1 oil on every metal porshion of the knife. as lude, a light coat over the blade and a lil on the nickle silver bolsters. i do this once a mounth
Frog lube made for guns generally. Food grade(American ) works awesome on guns smells good you would want the past for knives tho
Im shocked no one has mentioned Frog Lube ... I use Tuff Oil and Rem Oil on some of my knives but I use Frog Lube on those I know will be used for food prep ... and it is a decent lubricant ... have had no issues at all with it
I hate to bring up an old thread but I use WD-40 dry lube ptfe spray. Pretty good stuff but it really doesn't last too long.
Try Ballistol. I first got it from Spyderco outlet store several years ago. I found it on the by net googlin Ballistol. According to the info I received it is amazingly human friendly and has many uses beside lube and rust preventive. I like Miltec and I think it is inviro friendly and it is agreat lube but it is not a rust preventive.
I am surprised that it was at a Spyderco outlet store. I have read that Ballistol will eat up the bronze phosphor bushings. I have Ballistol and do wish I could get a definite answer. I would love to use it, but don't want to take the chance of it harming anything. Until then, I will stick to Weapon Sheild and Militec.
It won't "eat" them, it may slowly over time slightly etch and remove copper fouling from a barrel, but it's not aggressive on solid copper and bronze at all.
I'm going to answer this very soon, Iv had a 55gr .223 bullet soaking in a ziploc with several ounces of pure ballistol for over half a near now. When I feel like its been long enough I will pull it out, examine and weigh it. If a bath in ounces of ballistol won't badly etch copper, I wouldn't worry about the tiny amount used to lube. WeaponShield is the better lube though. I use it on anything that I don't plan to routinely use on food.
Thought this was interesting (in bold) what emerson uses... never tried it myself. I use froglube personally.
Dear Members,
I was looking through the forums and happen to come across this post. I just finished replying to an e-mail from a customer regarding this subject. I thought it might be relevant here so I've included it below.
Best Regards,
Ernest Emerson
Dear xxxxxxxxxx,
As with everything we do, it is purpose driven. Although many not knowing the history of Emerson Knives think that we are just another Knife Company, the roots of this company are buried deeply in the history of the Naval Special Warfare community.
Per the requirements set to us by NAVSPECWAR, all of our materials were dictated to us by the environment they were to be used in. Since SEAL operational duties require exposure to marine environments, all of the materials chosen for our knives had to both function and not degrade upon exposure to salt water.
You may note that we were also the first company to use Nylatron washer bearings for that same reason. Although they may be smoother, bronze or brass washers degrade and oxidize almost immediately upon exposure to salt water. Just another reason that Emerson Knives are different from the other knife companies that just claim to be "hard core."
The lubricant that we use is a graphite grease impregnated with copper specifically used for its waterproof and stability (longevity) properties. This lubricant does not wash out or break down even under years of exposure.
I do not build knives for collectors or casual users. I build them for the hardest users and the most extreme environments on this planet.
The reason that there are people who take their Emersons apart to clean or re-lube is simply, because they can. Emerson Knives was the first Knife company to make knives that could be completely disassembled by the user. This was impossible for any other production knives at the time and voided the warranty for most production knives. Once again, knowing both the purpose and the environments our product would be serving, I built the knives to be just like a gun. You can take it apart, clean it, tune it and replace parts as needed. No other so called "hard core" knife company even understood that simple need.
On my own knives, I have never ever changed the lubricant on any of them and some I have carried daily for over 5 years. They are knives that I simply picked up off the assembly table and put into my pocket.
I build my knives to a different standard. A standard unknown or perhaps ignored by other knife companies and a standard probably not understood by those who are casual users of Emerson Knives. That standard is so that any and every Emerson Knife can be carried into the harshest and most extreme environments on this planet and perform anytime, anyplace, without concern.
So in the end to answer your question, what purpose does it serve? I hope I have given you an answer.
Thank you for your support of Emerson Knives.
My Best Regards,
Ernest Emerson
I take back anything bad i have or may have or denied saying about emerson knives.
