- Dec 30, 2008
Words and pictures please
. I had a toss up between the sebenza and zaan
I found the Umnumzaan blade blunt at a certain angle - i.e. if you applied pressure with the blade laid straight on a normal photocopy paper rested on a flat surface, it doesn't cut (a cheap box cutter would've made a clean slice through the paper).
Also, is it normal for one side of the polished edge to be larger than the other side?
I also found my Umnumzaan tends to pit/nick fairly easily (see the micro nicks as shown): I stropped the knife to get rid of the scratches on the polished edge. It has only seen light duty cutting fruits and bait fish, opening letters and boxes etc.
I've always liked the look of the Umnumzaan. I think this thread pushed me over the edge. I got one on the way.
It will be really cool if Damascus steel is introduced for the Umnumzaan.
The blade geometry is very different on a box cutter blade than on an Umnumzaan blade, try dragging both of them across you hand and see if you think there is much if any of difference then. They will both cut you.
An uneven bevel while pehaps not normal is not unusual and makes no difference to the fucnction of a knife, especially so on a knife that will be used as it will be sharpened out in no time at all.
The chips you show in your picture were similar to the the small chips I got in my blade from trimming some ply wood. Again not normal but not unusual when cutting dirty or abrasive matrials. This seems to be much less of an issue for me after sharpening the knife several times and having used it for a good while.
Is this chipping any less common in S35VN blades, since it supposedly has a higher toughness than S30V?
Thanx,
Jim
