NJBillK
Custom Leather and Fixed Blade modifications.
- Mar 27, 2014
I understand that, but the way that I was looking at it is if he wanted thinner than, he would have stated that. I can suggest a DPx Heat, but it is wider with a shorter blade, but hey, it is an option right?
With the Vast array of knives available, there should be quite a bit to pick from that are close to his specified dimensions without muddying the waters too much.
I would like to think that he appreciates the input and the multitude of options available to him, but I cannot speak definitively for him.
As far as my being agitated; I don't know where you got that from, as I didn't state anything that could be construed as a personal affront, or standoffish. I simply highlighted what the OP said in his initial post for emphasis.
- Would you prefer I use italics or underline it next time? This way we can avoid the kerfuffle.
If That means I am agitated, then I feel that you should take a breather, since you have been reading way too much, and I had no agitation in mind. I only offered a reiteration of one of his criteria that weren't being met as accurately as possible when there is apparently enough out there to "pool the masses".
