Originally posted by thombrogan
What are your and Mr. Janich's other aversions to an axis lock? That other people could disengage it or that you might accidentally disengage it? While I'm more of an Extrema fan and Spyderknut these days, I like that other people can disengage my axis locks. It makes loaning the knife out at holidays that much easier. As for accidentally disengaging one while using it, I haven't had that happen. I've used my 806D2 for poking and prying out wood, sometimes with full force and added bodyweight, and that risk never materialized.
axislock disengagement is only a theoretical possibility during combat where a forceful thrust/withdrawal movement occurs, since disengagement could happen after a full thrust connecting with hard tissue (ie, bone, etc) could cause enough choking up on the handle to pull the lockbar backward & disengage the blade during the withdrawal motion.
^^those are pure theoretics, granted - and VERY far-fetched, as is the lone possibility of blade combat or self-defense.. like i said, it's just a personal pref thing, but that's the theory behind the neuroticism.
nevertheless, i'd feel more comfortable using my aftershock flipper in a combat situation, because there's no chance of twisting it into disengagement (the liner isn't exposed laterally; it's flush with the machined shape of the choil), and the only way to disengage it would be to collapse the titanium liner, which is thick enough to preclude any chance of over or undersliding the blade tang. even if you did disengage it somehow, the guard/flipper would meet your finger before the blade ever could. btw, i've successfully spine-whacked the thing on solid, non-damaging surfaces upon the suggestion of BF forumites.
i promise to post some shots of it once i get a digicam. lol, i have the same obsession with my customed-custom green canvas micarta aftershock (i put a longitudinal satin finish on the hollow grinds with 1500-grit wet/dry) as glockman99 has with his cherished al mar sere
