- Oct 20, 2009
Thinking of convexing my Boker plus Rhino.
It has a hollow grind on it now.
What do you guys think of this?
Simple hand sharpening with a stropping on leather will be more than enough convex for the bevel.
Paper wheels would work well also wouldn't they.
O yes... better than anything for the next 100 years.....
I'm not too keen on convexing, but using wet/dry sandpaper pinned to a foam mouse pad will suffice.
I think convex edges are mostly a marketing gimmick with perhaps a slight performance enhancement suited primarily to axes and large choppers, where wedging might be an issue. But I was reading on another forum, that practically worships convex edges to an almost humorous degree, that the mousepad is no longer a recommended substrate. Apparently they are just now realizing the inherent risk of convexing by hand - having the abrasive in one misguided stroke run over the apex of the edge, thereby instantly destroying all the hard work that was put into sharpening. But in any case, the party line there seems to now recommend a harder backing, though I assume this would provide less of that magic convexness that is so chic right now.
the hollow grind on the rhino left a thick shoulder on the knife that has to be taken down to make it a good slicer.
This is the exact reason I am such a fan of convexing now. That shoulder at the top of the secondary bevel creates a lot of resistance when cutting, especially in harder materials. I may have to give my EDC folder a convexing.
