Oh, and LightGuy, an afterthought I just had...it may be fastest to grind away most of the material with the dremel and then take off the last bit with the file. This will keep the end result flat and cut out some filing time. Either way, I can't wait to see your results. I'm just thinking with the tools that you will have.
Cool, I'm looking forward to it. Btw, I'm sure u have used your grinding wheel on your dremel, but just in case, they tend to 'run away' if you aren't careful. I would hate to see it grab the stud and 'run' down to your blade. Just another thought and that's all from me. Good luck.
Later,
Kevin
So the way I did it was I removed the blade and clamped it between some scrap wood to my workbench with the stud up. I just used a flat file and took my time to flatten/slightly round the top to where I wanted it. Then I used progressively finer paper in a block to get the level of polish I wanted. If you are going to polish the whole stud to remove the blue, make sure to tape the blade around it so you don't polish the blade. In fact, tape the whole blade anyway before you do anything in case the file slips.
If you can remove the stud, it gets even better because you can just chuck it into a drill and spin it while sanding/polishing. You would get a much more uniform result. In fact, that is how I scotchbrited my screws.
Also, just my 2 cents, but if a knife is going to be a user, you SHOULD do everything and anything you are capable of to make it as perfect as it can be for you. I plan on using this knife until I die and then I expect my son to take it and modify it for him. These are tools and as such should work for the user, not for the maker.
I'm going to have to confiscate man cards for anyone openly admitting their thumbs are sore due to knife opening. PM me for address...Thanks!
After that, go ahead and mod your knife! It's YOUR knife, that's half the fun!
On a more serious note, I will need that man card. Thanks!
The thumbstud for the Sebenza is not perfect but it can be opened very
easily if you do it the right way. When you begin to open the knife your thumb
should be behind the stud so only your finger nail is touching the side of the
stud. From here you can flick it open or open it slow. Your thumb is only going
to hurt if you press down on the stud with the pad of your thumb which is the
wrong way to open a Sebenza.
That just seems very unnatural to me for some reason. I've never opened a knife using my fingernail. With practice I guess I could try to get used to it, but I'd rather just fix the thumb stud and open it the normal way (to me).
Good video
[youtube]HcXu6dVRCOE[/youtube]
