I dont usually step into these type of discussions (cause I typically put my foot in my mouth and go DDDDOOOOEEEE)
but, I just dont know. MIG, TIG, GMAW, GTAW, and all that.
I havent burned 1 once of production wire since 1997, and even then, not so much on ferrous material as non-ferrous, i.e. Nickel (70%)-Copper (30%), Copper (70%)-Nickel (30%), stainless 308, 316L, and others all with TIG, their I go again, I mean GTAW.
Blah, Blah, Blah, Blah
When I was learning the trade, going through the apprenticeship in the mid 70s, I was told that MIG is an outdated term for GMAW. The acronym MIG stands for Metal Inert Gas. In the very early days of MIG, the shielding gas was Argon 100%, which is an inert gas. As welding R&D progressed they started mixing reactive gases with Argon or just using reactive gases by themselves (i.e. Carbon Dioxide) as shielding gas. The reason for the added elemental gases was to affect the arc in a positive manner. Since they were no longer using totally inert gases alone, they changed the acronym and name to GMAW, Gas Metal Arc Welding, and TIG to GTAW, or Gas Tungsten Arc Welding. In my old pipe welding days at Electric Boat, when I first started with Cu-Ni, we used strictly Argon as a shielding gas. This left a heavy oxide on the top of the weld puddle and was a real bugger to get good penetration or fusion without using excessive amperage. As time went on, that old R&D started actually mixing hydrogen (very reactive) with the argon, 5% H and 95% Ar, wow, you should see what happened, that molten metal would just about dance around in the middle of that puddle, with much better penetration and fusion.
When you weld two pieces regardless whether they are both the same material or dissimilar metals full or partial penetration, you create a Heat Affected Zone
their we go again another acronym
HAZ. A HAZ is apparent at the toe of the weld, which really leaves a brittle area, AKA a Martensitic grain structure (I dont know if martensitic would be appropriate hear but non the less you have an allotropic [just had to use that word]
transformation.)
When you post weld heat treat, is when you relax the stresses that were built up from welding. Dont ask me for another metallurgic terms like those mentioned earlier, because I dont know what one should be used, banite, pearlite, whatever.
Here I go again talking too much. But while I am, lets talk about swords breaking in the tang area. Now this Ive only read about cause I am a real newby when it comes to knife making, but, reading from The Complete Bladesmith, I believe that a chapter on swords talks about harmonics running the length of the steel when hacking, chopping, etc. apparently these harmonics can have a disruptive affect to the steel, usually at the smallest section, namely the tang (I'll bet this pertains to chopping length knives), I dont believe that a welded on tang was being referred to in the text.
I guess regardless whether your tang is welded, forged, or stock removal, on a chopping type of blade, if you do not account for these vibrations (harmonics) in your design and execution of construction, you run the risk of metal failure.
I think I'm done, I'd say this is just my 2 cents, but that was at least a quarter.
Larry T
Member of NECKA & NCCA
