It's true that it's mostly a matter of personal preference or how you train My personal preference is tip up . Tip up is more dangerous because if the blade opens partially and you put your hand in your pocket you may get cut. Still, if it opens alot tip down you may get cut on the leg, but that's less common. Having the blade rest against the seam does help, unless the knife moves as it may if you are active. In either case you have to check the knife regularly to make sure the pivot isn't too loose and train your self to be careful either way.see I dont get the tip down for security . can you explain that? this coming from soemone who prefers tip down
Tip up. My thumb goes in the pocket and reaches the stud, hole or flipper as I grasp and pull. I have tried tip down but it feels awkward.
I look at it this way.. take your folder, open it, close it, and without changing your grip after closing, put it in your pocket. How does it go in? Tip up right?
Up is my preference. It puts my thumb right where it needs to be to deploy. No having to flip the knife around in my hand first. It also puts the blade spine against your pocket so less likely for the blade to open if you have a soft detent.
